rear bulb got damaged
Old 05-03-11, 10:52 AM
ricardo304
ricardo304's Avatar
Default rear bulb got damaged
Good morning, i'm new at this forum and i need a little help. i own a 90' ls400 and my dashboard shows a tail lamp failure, so i changed the broken rear bulb and the indicator got off but some minute later another rear bulb got damaged and the indicator went on again. i fixed it again and again another bulb got damage. what can I do? if i change all the rear bulb by led bulb will it fix??
Old 05-03-11, 11:06 AM
Hilux22RE
Hilux22RE's Avatar
LED Bulbs Draw less power than a Standard Bulb. So Changing them out with LEDs will not make the Lamp Failure light turn off unless you add a Resistor to the Circuit..
Old 05-03-11, 12:28 PM
RA40
Super Moderator
RA40's Avatar
Also, the 1-LS known to have a short in the wiring over time on the trunk harness. Check the wires along the support arms for insulator wear. Check that the bulb socket is also in good condition. Some of the contacts may be worn there.
Old 05-03-11, 02:26 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
this.
http://www.lexls.com/tutorials/lighting/bulbout.html
Old 05-03-11, 02:53 PM
ricardo304
ricardo304's Avatar
thank u all guys, i apreciate your help i'm going to check the trunk harness this weekend.
LS430inDE.
05-27-19 10:32 PM
EkimAtled
12-04-18 11:11 AM
willtan
RX - 3rd Gen (2010-2015)
08-28-16 08:57 PM
SammyRed
02-14-14 05:58 AM
path
09-06-11 12:40 PM
Quick Reply: rear bulb got damaged
