Water coming behind the driver seat
Old 04-21-11, 09:52 AM
sjaffry
sjaffry's Avatar
Angry Water coming behind the driver seat
Hi,
I have a 1995 LS400. It rained yesterday and today when I opened the rear door of the car, I saw the carpet behind the drive seat was all wet and had a lot of water. Every thing else except the carpet behind the driver seat was DRY. All the windows, doors and SunRoof was fully closed.
One of my friend told me that this might be a drainage issue. Can someone please help.
Old 04-21-11, 12:43 PM
Dtwillis5
Dtwillis5's Avatar
Put water on your car by the sunroof and check the ceiling inside your car to see if water getting in your car from there
Old 04-21-11, 12:46 PM
etex
etex's Avatar
Might check under the front floor mats to see if that area is wet. If so, your A/C drain might be stopped up.
Old 04-21-11, 05:58 PM
deanshark
deanshark's Avatar
It's deffinately a drainage problem. Check the bottom of the trim between the front and back door to see if that's where the water is coming from. I think that's where the drain is for the gutter system above the doors. Either that or, being from NY, it could be part of your floor is rotted and the water is coming through the bottom.
Maybe you spilled a bottle of water.
Old 04-21-11, 06:50 PM
emarknot
emarknot's Avatar
there is also an air vent under the seat as well.....check for water in there
acegunter
02-21-22 09:11 PM
starstreak
09-24-15 09:09 AM
starstreak
03-10-11 08:22 PM
RoLux707
01-05-10 07:25 AM
Kodachi
SC- 1st Gen (1992-2000)
09-28-09 06:58 PM
Quick Reply: Water coming behind the driver seat
