1992 ls 400
Old 03-14-10, 06:53 PM
dman02445
dman02445's Avatar
Question 1992 ls 400
What is your opinion about an 1992 with 134K miles with no timing belt work done, nothing done to power steering /rack and pinoin system, nothing done to ac compressor, or abs actuator. I have heard that these items need servicing especially after 100k. Does the 'if it is not broke don't touch it' rule appy here?
Thanks in advance for replies.
D
I should add that full service was done after 100k, would full service pick up a power steering leaking, rack boots torn or leaking or problems with the timing belt and advise change? I am a novice at this!
Last edited by dman02445; 03-15-10 at 08:12 PM. Reason: update in reply to the response.
Old 03-14-10, 07:28 PM
LiCelsior
Retired
LiCelsior's Avatar
welcome
timing belt- asap
power steering- probably leaking
rack- boots probably torn or leaking
ac compressor- if not overcharged should b fine
abs actuator- should be fine
up to you if u want to implement the not broke dont touch rule but it will snowball.
sayow
10-27-15 01:28 PM
Biggu
Performance & Maintenance
05-15-12 08:57 AM
gs300_94
GS - 1st Gen (1993-1997)
06-04-11 06:29 AM
AD_SC3
07-01-10 10:50 AM
hempnight
SC- 1st Gen (1992-2000)
05-23-10 08:01 PM
Quick Reply: 1992 ls 400
