Experts - HELP
Old 10-01-09, 11:20 AM
ur2slow1
ur2slow1's Avatar
Default Experts - HELP
Ok guys I recently replaced the strut rod bushings on my 2000 LS w/ poly ones. The noise is absolutely unbearable (squeek/squeek/squeek) whenever I go over bumps........Does anyone make rubber replacement ones ????
Old 10-01-09, 12:18 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
no, you can replace the entire bar.
a pair costs about $220-260 from one of our sponsors.
out of curiousity, does your car makr cracking/creaking noises when you turn the steering wheel?
Old 10-01-09, 12:23 PM
Amskeptic
Amskeptic's Avatar
If the squeak only showed up after the replacement and you are confident that it is the polyurethane bushings, try applying silicone grease to contact surfaces.
But usually, suspension or shock bushings are designed to never have actual movement. They are supposed to be fixed, and the only movement allowed is the intrinsic compliance in the rubber itself. That is how shock and control arm bushings can survive hundreds of thousands of inner city potholes perfectly fine, but go out in a month when the rubber lets go and starts to slide on the metal.
Strut rod bushings barely have any opportunity for movement other than just waiting for compression/tension from braking, etc. Control arm and shock bushings? 'nuther thing all together.
Colin
Old 10-01-09, 07:01 PM
ur2slow1
ur2slow1's Avatar
Ever since we installed the new poly strut rod bushings the car creaks like crazy when going over speed bumps or when pulling into/out of a parking lot or driveway. May be time to just break down and buy the new rods from a sponsor
Old 10-01-09, 08:41 PM
trukn1
NELOC Mod
trukn1's Avatar
The poly bushing squeak is an indicator that there was not enough of the grease applied to them before install. I have poly bushings in all of my suspension components, except for the strut rods(yet) and not a squeak at all. Press the bushing back out and reapply with a very LIBERAL amount of grease. One tip that I did when I replaced any of my bushings was once I cleaned up the area, I took a wire wheel to score the metal surface a little and applied grease to that surface as well as the bushing itself. Been 3 years now, have daizens installed, and not a squeak.
Old 10-02-09, 11:53 AM
Lexkost
Lexkost's Avatar
It maybe your sway bar bushings
OMAHA
10-30-18 10:13 AM
9000revs
02-02-15 06:43 PM
billydpowe
13
11-10-10 04:11 PM
JLund
12-30-08 10:49 PM
Bali26
03-01-08 09:22 AM
Quick Reply: Experts - HELP
