How long does it take for a timing belt to crack?
Old 08-23-09, 03:17 PM
Lexozz
Lexozz's Avatar
Default How long does it take for a timing belt to crack?
I have a '98 LS and inspected the TB, noticed that there are cracks on the smooth side. How long does it take these cracks to show after initial installation? When I had my '95 I had the TB change due to the same condition, but when I looked at the teeth it show no sign of wear. Do I need to worry about the TB snapping?
Old 08-23-09, 03:32 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what's the mileage since hte last change?
Old 08-23-09, 03:53 PM
Lexozz
Lexozz's Avatar
I bought used with 141,000 back in November, and the dealer swore up and down it was changed at 100k. It has 20k more on the clock now.
Old 08-23-09, 03:56 PM
PureDrifter
BahHumBug
i'll check my repair manual and see hwat it says.
Old 08-23-09, 04:35 PM
python
python's Avatar
7 years or 90-100,000 miles...if u saw cracks i suggest u change it no matter what
Old 08-23-09, 10:17 PM
dfkd
dfkd's Avatar
Not even worth negotiating with yourself. When those valves hit the pistons you'll be looking at way more that the 1500 it costs to have the belt replaced (assuming you don't diy it).
The teeth should never show signs of wear clearly. When I replaced mine I could see that the weakest part of the belt (where it would fail) is definitely the thinner section between the teeth and on mine, that's where the cracks were. Mine hadn't snapped tho.
I'd say cracks = replace, especially in that interference 1UZ you have there.
Old 08-23-09, 11:47 PM
skperformance
skperformance's Avatar
Are you asking about your timing belt or serpentine belt .
As if you inspected a TB then you only saw the serp .
The timing belt is under a cover that needs to be removed to see. Inspect it every 4-6 months after 100k once you see any fraying it will only last another 10000-15000 K
Old 08-24-09, 12:29 PM
JimsGX
JimsGX's Avatar
Lexozz: "How long does it take for a timing belt to crack?"
With water boarding techniques, much sooner than later.
Anyways, I changed mine after 16 years and 72k miles.
Old 08-24-09, 01:53 PM
stargazer0
stargazer0's Avatar
Default 11 Years and 165K miles
I am in the process of changing mine now after 11 years and 165K miles. I am a DIY person but...I would recommend only Lexus parts for the timing belt. I don't know what it looks like...but I do know that its been a long way past the 90k mile mark that is recommended.
Old 08-24-09, 02:00 PM
tromly
tromly's Avatar
Hey Jims, you obviously like to live on the edge, man that is taking a chance
Old 08-24-09, 03:18 PM
Max Power
Registered User
Max Power's Avatar
lol!
I had mine checked out and it seems that the belt was last changed at 95 000kms. The car now has 215 000kms. They said it was time to do it again.
It seems you guys in the states are doing the t-belt replacement later than what I'm being told. Whats the deal?!
Old 08-24-09, 03:29 PM
JimsGX
JimsGX's Avatar
Sorry Colonel!!
Old 08-24-09, 04:56 PM
PureDrifter
BahHumBug
jim has a first gen LS, non-interference motor=no worries
Old 08-24-09, 07:21 PM
stargazer0
stargazer0's Avatar
I just took off the Timing Belt covers. My timing belt has the cracks in it also and the teeth look fine...but this is after 165k miles on a car I bought new and have never changed the Timing Belt until now.
Old 08-25-09, 12:54 AM
Max Power
Registered User
Max Power's Avatar
How long does it take to get the timing belt cover off?
Quick Reply: How long does it take for a timing belt to crack?
