How critical is it to use Genuine Lexus stuff ??
Old 04-13-09, 04:20 PM
Horsepwr
Horsepwr's Avatar
Default How critical is it to use Genuine Lexus stuff ??
Ok ,I have the fun task of replacing the timing belt and water pump .Going to be replacing the starter also .Are there any brands out there that I should really stay away from when speaking of these items ?Does the timing belt REALLY need to be a Toyota belt ?Same with the water pump ,and starter .I called Lexus today ,and they must thing Im some executive at AIG ,that got a larger sum of money .PLEASE HELP !!Are gates belts any good ?
Old 04-13-09, 04:30 PM
LiCelsior
Retired
LiCelsior's Avatar
get the parts from our dealer vendors on the forum. they give a nice discount and use OEM parts. i used a ebay brand starter for my car, works fine.
Old 04-13-09, 05:14 PM
python
python's Avatar
i wouldnt use anything but a denso starter...period, too much is involved in getting the starter in and out, also i hope u replaced your knock sensors and connectors
Old 04-13-09, 05:25 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
carson toyota aka L-tunedparts.com for all your OEM parts needs
and yes, buy genuine, you won't regret it.
Old 04-13-09, 06:15 PM
EUBT
EUBT's Avatar
Cool
Everything I use is oem. Like the guys said, if you check around you can find prices that are more reasonable than the stealer's. Stay with oem, especially if it's buried like the tb and starter. Even the simple stuff can give you headaches. Like getting aftermarket plugs, bulbs, filters, etc. With oem you also get the bonus of knowing that your part is not a piece of crap from china.
Old 04-13-09, 06:25 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
You can find sellers on Ebay that will rebuild your start (or sell you a rebuilt starter) using OEM denso parts. Starters can be had for anywhere between $100-$150 rebuilt with OEM parts.
Like many have mentioned before me, there are areas where you dont want to gamble, or save money.
Old 04-13-09, 07:39 PM
Horsepwr
Horsepwr's Avatar
Thanks for all the responses guys .Looks like Ill try to stick with oem stuff .Does anyone know if when doing the timing belt / water pump ,are the cam seals very acessible ,should they be done also ?
Old 04-13-09, 08:27 PM
PK_Celsior
PK_Celsior's Avatar
i believe they are accessible while the valve cover is off also :x but dont quote me on that. but i did remember seeing it while i was redoing my valve cover
good picture of it
Old 04-13-09, 08:48 PM
PureDrifter
BahHumBug
on the 98-00 with the VVTi motors it's a whole lot more work to do the cam seals as you have to remove the camshafts.
Old 04-14-09, 07:39 AM
Horsepwr
Horsepwr's Avatar
Ok ,I more than likley will not replace them then .Besides ,it's not leaking any oil at this point .Im sorry for the battery of questions ,but does it make sence to do the starter at the same time as the timing belt ?My buddy is actually doing the timing belt for me ,and I was thinking of replacing out the starter at the same time ,since I believe it is on it's way out .Thanks again
Old 04-14-09, 10:44 AM
PK_Celsior
PK_Celsior's Avatar
the start goes on a different pathway. to do the starter you take off the intake manifold and all that good stuff. might as well do the whole valve cover camshaft seal.
Neil4Speed
SC- 1st Gen (1992-2000)
04-26-12 01:08 PM
Neil4Speed
Performance & Maintenance
11-03-11 01:37 PM
2jznosht
08-28-11 07:15 PM
Scott1258
05-15-11 02:41 PM
avalon42
02-12-07 04:59 PM
Quick Reply: How critical is it to use Genuine Lexus stuff ??
