Multi Function Display - Incorrect info
Old 03-06-09, 07:26 AM
jb904
jb904's Avatar
Default Multi Function Display - Incorrect info
my 98 ls400 had its check engine light come on. I havent been able to find out what it means just yet but since its been on i havent noticed any change in how the car drives. i drive in the city but im easy on the pedal driving like granny and my display is showing 20 mpg average. however after filling up my car recently i did the math (total miles driven/gallons filled) and the actual mpg is 14. If my display is somehow off how would i fix that? Or is it a chance that the check engine light is causing the misread for the MPG?
Old 03-06-09, 11:26 AM
selkirk
selkirk's Avatar
The average calculation is calculated since it was last reset - did you reset it when you filled the car up last time?
If you reset it partway through this tank, or if you last reset it a few tanks (or more?) ago and did some highway driving since then, that will influence the average it tells you.
350rx
10-13-18 09:24 PM
alpinefun
ES - 6th Gen (2013-2018)
03-12-14 05:46 PM
markwill12
07-22-13 05:49 PM
vicsc300
SC- 1st Gen (1992-2000)
05-12-08 06:03 PM
mm9351
04-10-06 05:53 PM
Quick Reply: Multi Function Display - Incorrect info
