98 LS front brakes/rotors
Old 10-14-08, 12:36 PM
projman
projman's Avatar
Default 98 LS front brakes/rotors
I've decided to fix some of the nagging issues with my 400 as opposed to trading it off. I've searched the forums to no avail.
First thing is a left front wheel bearing. The bearing and seal are purchased and I can handle that job.
The next thing is the brake pulsation I have. I replaced the pads a year ago or so and there is still plenty of material there. But, I don't think I performed the job correctly. In hindsight, I should have had the rotors turned at the same time. So, I will do the job again.
What is the rotor min thickness (again it is the fronts, 98 LS)?
I'll replace the rotors (Brembo, plain) if I have to but I rather turn them if possible.
Thanks in advance.
Old 10-14-08, 01:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the min. thickness is stamped on the rotors
Old 10-14-08, 04:05 PM
projman
projman's Avatar
Thanks Drifter.
From what I've seen on here, it appears TireRack is the best price for Bembo blanks. Anyone have any better price somewhere else? I've got a friend mechanic that says in the last couple years, he's had good luck with the cheap ones from Autozone. Anyone here tried those? Any thoughts?
Old 10-14-08, 07:40 PM
PureDrifter
BahHumBug
i like my brembo blanks...
Old 10-15-08, 10:58 AM
atoyot
atoyot's Avatar
i would suggest trying to re-seat your brake pads before you go turning your rotors. A lot of rotors do not behave well to being turned, my landcruiser is a example. When you turn those rotors, they will be warped within 5,000 miles almost every time.
Its important to seat new pads when you put them on.
Many times material builds up on the rotors from heat cycling. Re-seating the pads removes this material for a smooth surface.
Old 10-15-08, 11:08 AM
projman
projman's Avatar
atoyot - how do you re-seat existing pads and rotors?
Old 10-15-08, 11:16 AM
PureDrifter
BahHumBug
you have it backwards, if you don't bed the pads/rotors in properly when both are fresh, the pad will leave deposits on the rotor ("warping" it).
when you turn the rotor you are supposed to replace the pads. If you replace just pads, you need to at least scuff up the rotor with a scotchbrite pad to roughen it up and give it some bite to bed the rotor in.
Old 05-21-10, 06:17 PM
chaplir
5th Gear
chaplir's Avatar
Question
Where exactly is it stamped?
Old 05-22-10, 01:25 AM
PureDrifter
BahHumBug
along the edge, it's likely that its rusted over a bit so take a wire brush to the edge of the rotor.
Old 05-22-10, 06:33 AM
chaplir
5th Gear
chaplir's Avatar
thanks.
Old 05-22-10, 06:48 AM
McSwine
McSwine's Avatar
I've been using the Brembo blanks (from Tirerack) and stock pads for the last several months without issue.
Old 05-22-10, 07:09 AM
LiCelsior
Retired
LiCelsior's Avatar
r1concept slotted rotors and ebc red pads ftw. saved me from a huge manhole cover yesterday lol..40>5mph with ease.
Old 05-22-10, 10:44 AM
etex
etex's Avatar
No attempt to hijack here... but, if Akebono pads and Brembo rotors are replaced together on the same 98 LS400, is it necessary to bed them?
Old 05-22-10, 03:08 PM
PureDrifter
BahHumBug
yes you still need to bed new pads to any rotor.
Old 05-22-10, 05:37 PM
etex
etex's Avatar
Would this same answer apply if the pads are ceramic? I think I saw on here someplace that ceramics didn't require the bedding process.
Quick Reply: 98 LS front brakes/rotors
