Rear Diff
Old 05-07-08, 02:29 PM
shaned1320
shaned1320's Avatar
Default Rear Diff
i was wondering if anyone knew how many quarts it takes to put in a 96 ls400 differential i was told 1.4 quarts but i just want to make sure
Old 05-07-08, 06:26 PM
steveski
steveski's Avatar
Welcome to CL. I had a long day and am too lazy sadly to go out in the garage and look in my factory manual
1.4 quarts is recommended for pre 1995 though. The common method is to fill it to the bottom level of the fill hole. Not sure if it is 1.6 Quarts or 1.8 Quarts.
Old 05-07-08, 10:15 PM
DIY LS400
DIY LS400's Avatar
Just get two quarts of gear oil and fill until it dribble outs of the fill hole.
Old 05-08-08, 01:32 PM
trukn1
NELOC Mod
trukn1's Avatar
Having just changed my differential on my 92. It took 1.5 quarts from BONE DRY. As the others have said, just fill it until it starts to dribble out of the fill hole. This will be enough.
Old 05-08-08, 02:03 PM
GSteg
GSteg's Avatar
Also I would jack up the car both on the front and the rear end so the car is more leveled. You can go at least 0.2 quarts below recommended dosage just by having the front of the car on the ground.
Old 05-08-08, 09:41 PM
shaned1320
shaned1320's Avatar
yes i will be doing it on a lift at my shop, thanks guys
Old 05-08-08, 09:46 PM
DIY LS400
DIY LS400's Avatar
Btw does it matter if you overfill, like when the rear end is up in the air and the fronts are on the ground?
OldLs400
08-22-18 11:46 AM
SMCK
07-06-18 01:35 PM
112motor
10-24-11 07:48 PM
brickauto
GX - 1st Gen (2003-2009)
04-07-08 06:43 PM
Quick Reply: Rear Diff
