Sway Bars
Sway Bars
I have a 98 LS400 and it sways a lot on turns. Should I replace it with a original one or are there better ones out there and if there is where is the best place to buy. The car just turned 100k miles.
THANKS
THANKS
The cheapest thing to do to reduce body roll would be to simply install some polyurethane anti-sway bar bushings. The stock ones are rubber and as such can flex and stretch during cornering. Daizen makes quality polyurethane bushings that are listed on their site at http://www.daizensporttuning.com/pro..._bushings.html. As far as installation is concerned, there is an excellent tutorial available at http://www.lexls.com/tutorials/suspe...enswaykit.html. Although it's for a 1st generation LS400, it should be similar enough to help you with the installation process on your 2.5 gen.
Kajukenbo
Suspension and Brakes
10-29-02 02:50 PM
