ls400 coach TRACTION CONTROL button
Old 08-27-07, 12:49 PM
Whiteglove
Whiteglove's Avatar
Default ls400 coach TRACTION CONTROL button
i have a 97 ls 400. i believe since in the coach edition they put the button somewhere else than the normal version. i have looked in the manual and it states it should be right above the gear **** and below the radio/sound system panel. i might be completely retarded but ive looked all over.
Old 08-27-07, 01:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it was an option in 97 iirc, you may not have trac.....
Old 08-27-07, 02:01 PM
LiCelsior
Retired
LiCelsior's Avatar
i dont know if this works for the 2g ls400s but look under the hood to see if u have a trac box of some sort.
Old 08-27-07, 03:39 PM
sonyman
sonyman's Avatar
Traction control and heated seats (together as a bundle) were an option on 1990-1997 LS400's. If you don't have a button that says TRAC, along with driver and passenger seat heater controls also by the shifter, you lack this option package.
Old 08-27-07, 04:20 PM
PureDrifter
BahHumBug
you dont have to have heated seats to have trac >.>
Old 08-27-07, 04:55 PM
sonyman
sonyman's Avatar
Are you sure about that? I'm fairly certain 1990-1997 it was bundled.
Old 08-27-07, 05:17 PM
PureDrifter
BahHumBug
i saw a few cars with trac and no heated seats when i was hunting for my last LS.
dont think i saw a car with heated seats and no trac tho
Old 08-27-07, 06:00 PM
dashan
dashan's Avatar
I did test driving a Coach Ed 97 LS4 without traction control while I was purchasing my car.
Old 08-27-07, 06:37 PM
ewenpg
ewenpg's Avatar
I have a TRAC button on my 97 and it is located as described. If you dont have the button you may not either have TRAC or have the option to turn it off. My friend has a 06 IS350 and to turn the TRAC off it recquires a really weird hack.
Old 08-27-07, 09:15 PM
skperformance
skperformance's Avatar
The trac button is located on the wood center console under the radio directly under the volume button above the ashtray on the thin strip.
Old 08-27-07, 09:46 PM
PureDrifter
BahHumBug
on teh LS, if u dont have the button, you dont have the system.
djeffers
Performance & Maintenance
46
08-17-17 08:09 AM
slammed400
12-03-16 11:17 AM
Alpha1
03-16-15 10:33 PM
jdog0411
19
05-24-11 08:09 PM
vietstuh
14
06-01-06 09:20 PM
Quick Reply: ls400 coach TRACTION CONTROL button
