Airbag wiring Gen 1
Old 04-26-05, 03:04 PM
psls400
psls400's Avatar
Default Airbag wiring Gen 1
Can anyone confirm whether the wiring harness plug (white) on the Gen 1 steering wheel powers the cruise control and horn?
Upon close inspection, I can see a white "roll" of plastic strip that has contacts inside it. This roll is wound around the back of the airbag connector and I think plugs into a power source behind the steering column shround.
Any ideas?
Regards
psls400
Old 04-26-05, 11:04 PM
nthach
nthach's Avatar
general rule of thumb is all the airbag connections are yellow.
Old 04-26-05, 11:13 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
This took me 20 mins of scrolling through old posts to find, i hope it helps.
https://www.clublexus.com/forums/sho...96#post1254296
Old 04-27-05, 03:16 PM
psls400
psls400's Avatar
Exclamation Thanks GRAND_LS4
Thanks for the info.
All I really wanted to know was where the spiral cable connects to.
The spiral cable is wound in a spiral behind the airbag itself.
There seems to be a plug that connects to the spiral cable. This connector seems to power the airbag, cruise control and horn.
Is my observation correct and does the spiral cable slot into a spot or is it soldered?
BBriBro
Performance & Maintenance
09-26-09 07:57 PM
RedPhoenix
SC400 / 300 Classifieds
03-02-09 07:05 AM
andrewwake
SC- 1st Gen (1992-2000)
06-26-08 05:08 PM
bigd480
05-21-06 08:17 AM
psls400
04-29-05 06:06 PM
Quick Reply: Airbag wiring Gen 1
