Belts for '90 LS400 cassette? Where to buy?
I read somewhere on here that the belts in the cassette player in most Lexus' last about 10 years. I am pretty sure mine are shot because when I insert a cassette, it automatically switches from tape to FM. Can anyone recommend a place where I can buy the belts?
are you sure its the belts? can you eject your cassette tape?
if you cant eject it. it may not be your belts. what you can do is disconnect the battery for 5 seconds or so. and then reconnect. sometimes the cassette player acts up. it happened to mine and thats how i remedied the situation. so yah do this only if you are unable to eject your cassette tape.
I doubt you can buy just the drive belts for it. But however, if you know the cassette decks manufacturer you may be able to find a replacement belt. These belts usually look like large "O" rings.
Anyway, it may be a lot of trouble to replace the belt even if you find a new one.
My guess is that Lexus will only sell you a new unit.
Wes
Wes
Tape Cassette Belts
When you say "Threading Pattern" are you saying the belt has small notches or cogs in it? Is this not an "O" or "V" or plain "Flat" belt?
I think the first step is to identify the manufacturer and then try to find what the belt specs are. A lot of these devices use the same type belt, so maybe you can cross reference a replacement.
You may want to consider a wrecking yard. However a used part may be no better than your current part because it seems the belt deterioration is the result of age.
Sorry, I can't be of any more help than that.
Good luck and let us know if you’re successful. It may help someone else.
python; Us "old" guys still use cassettes, sometimes.
Routing direction?
0100 - first of all, i'd look for a junkyard stereo that works before trying to refurbish my existing stock stereo
0200 - Mugen, just do what I did and splice some 3.5mm headphone connectors in the line between the CD changer and the head unit. Perfect aux input.
LJBSJB
07-29-19 09:34 AM
PjLex
09-03-15 11:46 AM
