Outside temp sensor location?
Old 05-06-04, 05:57 PM
RA40
Super Moderator
RA40's Avatar
Question Outside temp sensor location?
Where is the sensor that reads the outside temperature?
While driving around today, it read a constant '95 degrees. Usually if it has been sitting, it reads high but after a bit of driving, it seems reasonably accurate...today it was way off.
Old 05-06-04, 07:01 PM
buttons
buttons's Avatar
behind rippled lower front end; toward rt side. remove lower flap to see.
Old 05-06-04, 10:21 PM
RA40
Super Moderator
RA40's Avatar
Found it...thanks Richard.
The last couple days it has reacted very slowly. Lexus wants $33.XX and it is a special order part.
Is there a test procedure to check for accuracy?
Old 05-07-04, 08:24 AM
buttons
buttons's Avatar
doubt it--if the service manuals had a decent index I would try to look it up--but they don't.
Old 05-07-04, 08:43 AM
MTS_Lexus
MTS_Lexus's Avatar
Check ambient temperatuer sensor?
Remove from radiator grill
Disconnect sensor
Check resistance between terminals 1 and 2
Resistance
at 77 degrees 1.6 - 1.8 Ohms
at 122 degrees 0.5 - 0.7 Ohms
As the temperature increases the resistance decreases
Old 05-07-04, 09:42 AM
RA40
Super Moderator
RA40's Avatar
Thanks MTS-lexus
I went looking through the service manual and came up for that particular sensor.
Damar595
06-29-17 06:45 AM
lonbon
GX - 1st Gen (2004-2009)
07-09-11 02:45 PM
mrchacon
06-26-09 05:22 PM
lex bubba
Performance
03-07-08 09:18 PM
LEX012006
01-17-08 03:13 PM
Quick Reply: Outside temp sensor location?
