Change out headlight bulbs...
Old 04-04-01, 02:46 PM
tn52
tn52's Avatar
I have a 93 LS400. Could someone gives me instruction steps to change out both headlight bulbs in the car? Any suggestion for a whiter and brighter bubs?
Old 04-04-01, 03:15 PM
SQ-LS
SQ-LS's Avatar
Hey did this several weeks ago with my 93 LS. Switch the OEM with some Piaas H4 bulbs. They look preety tight!
Instructions:
1. Open your hood first
2. Remove the air intake box and the battery to get room for your hands.
3. Unscrew the side lights (the ones next to your front head lights, and the screw is on top). Just one screw.
4. Gently but firmly pull them out (held in by one popper).
5. Unhook the 168 wedge light bulb (Now you have room for your hands).
6. Remove the plasitc protective covering behind the headlight (Just twist and turn it till it comes out).
7. Unplug the bracket that is connected to the H4 bulb.
8. Twist the grey round brace and pull it off.
9. Remove the protective rubber covering (you might want to armourall the rubber so it will last longer).
10. Unhook brackets holding the H4 bulb in and pull the bulb out (becareful in that when you unhook the bulb will automaticly fall out).
11. Replace and put everything back together.
12. Do the same for the other side.
12. Put the air intake and battery back.
Oh, while your changing the H4 bulb, you mine as well change the wedge bulb to to match the effect your going with the head lights. This should take you about an hour to do.
Good luck.
Old 04-05-01, 05:33 AM
tn52
tn52's Avatar
Default Thanks Lou Le
Anything should I do before I remove the battery? My most concern is my OEM Nagamachi stereo system then other theft deter. things? Will my car will start, stereo/radio will work after I remove the battery?
Old 04-05-01, 06:45 AM
SQ-LS
SQ-LS's Avatar
Everything will be OK.
Just remeber that once you take out the battery every memory set is lost (car seat setting, radio stations, what ever your mileage for A & B, etc.).
My recommendation is get your seat set where you like it and the side mirrors set and once you put the battery back just reset your seat memory. Radios and other things your gonna have to reset.
Hey while all that stuff is out you mine as well clean the engine while your at it!
Have fun now!
Old 01-18-05, 04:37 PM
Eenis
Eenis's Avatar
Do these directions hold true for the '97 halogen headlights as well? All of the directions that I saw were for the '91-'93. I was trying to remove the driver's headlight and the corner light seemed like it wasn't trying to come out. Just want to be sure before I yank it out that I'm doing the right thing. Thanks.
Also....what are the years of the Gen I and Gen II LS?
TS
Old 01-18-05, 05:32 PM
nagasakki
nagasakki's Avatar
90-94 1st Generation
95 above 2nd
nah those directions doesn't show how to remove headpiece.
IT's pain in the butt to take them out but I never bothered taking it out, i remember I got a hole size of a bb on my headpiece and water got inside and blew out my bulb. I couldn't get the headpiece out to shake the water off. Nor i couldn't even drill a dang hole on the headpiece with the drilling tool. dang that thing is like bulletproof but how the heck did I get a hole up there?
What I did was took the fog light out then pierce a hole thru side of headpiece, then drill a hole on bottom to drain all the water out. lolz. then I sealed the hole in front with silicone and cover the hole on side with masking tape.
Don't put high wattage bulbs, it'll melt/burn your wires. you need a wiring kit to add aftermarket high watt bulbs, such as xenon bulbs.
I could go check what the recommended and minimal wattage to use without adding the kit.
but i'm too lazy. Try Sylvania. those are safe.
Old 01-18-05, 05:38 PM
Eenis
Eenis's Avatar
Thanks nagasakki, but i'm looking moreso at the procedure. I'm not going to step up the bulb and try to get more output.....I just need to know how to get to the bulb. Thanks.
TS
Old 01-18-05, 05:45 PM
nagasakki
nagasakki's Avatar
oh..hm i'm not sure, is it LS4? well it may depend if the filter and battery is on the way.
those are only two things that needs coming out to reach bulbs.
sorry for misreading your post. I'm tired and at work. zzZZZzz
vinh
vinh's Avatar
this site helped me out a WHOLE lot
woot woot!!
Old 01-18-05, 05:48 PM
nagasakki
nagasakki's Avatar
Vinh your the man.
Old 12-14-05, 12:13 AM
PLaTNuM
PLaTNuM's Avatar
Exclamation head light problem
hmmm i got a question....last month i got in a small car accedent with a suv cause he tried to get into my lane while on the phone and knocked my right headlight out then took off after he realized how pissed i was anyways long story short i just got some replacment head light covers but i dont know what kinda bulbs to get...my friend offered me a roadmax 9004 12v 65/45W 130/120W metal white xenon head lights for like 10 bucks but i dont know if it will work for my car by the way i got a 92 LS400 please let me know asap before i get a ticket for having only one head light on thanx
Old 12-14-05, 03:52 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
9004 is the correct application for your '92. When you say "65/45W 130/120W" I'm assuming 65/45W => 130/120W, which means it runs at 65/45W, but simulates 130/120W output? You may want to get another one of those "xenon" bulbs to match the other headlight, otherwise you'll have one headlight that's blue-ish white and another that's yellowish white.
You might also consider Sylvania Silverstars, Mtec, PIAAs, RAZO, or Raybrig (pricing is from lowest to highest respectively). Use the advanced search funcion and you'll find all the answers you need, and then some.
https://www.clublexus.com/forums/search.php
Old 01-26-06, 12:01 PM
Phucanese
Phucanese's Avatar
what, so the 89-92 are 9004, but the 93-94 are h4?
wtf, i ordered some 9004 bulbs cuz the a few sites i checked said that for 93, its 9004 bulb.
why did lexus have to change the bulb size? its the same headlight!
Old 01-26-06, 04:28 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
go to sylvania.com and look for the bulb replacement guide.
they changed it because the 9004bulbs light output sucks compared to H4.
Old 01-26-06, 05:01 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Yup. The headlights look the same from the outside, but the reflectors inside are different.
Quick Reply: Change out headlight bulbs...
