Timing belt?
Old 04-27-04, 04:50 PM
dj.ctwatt
dj.ctwatt's Avatar
Default Timing belt?
How hard is it to change a timing belt myself? Anyone have a DIY?
Old 04-27-04, 10:21 PM
LexLS
LexLS's Avatar
Post
The only DIY I know of on this is on Lextreme's site: http://www.lextreme.com/timing.htm
It's for a 2nd gen LS but there is a link to the first gen repair manual instructions. Using both of these you should have enough info to DIY .
On a scale of 1-10 I would say that doing a timing belt change is either an 8 or a 9. I would consider a 10 to be a complete engine rebuild.
Old 04-30-04, 01:08 PM
hyperopt
hyperopt's Avatar
It looks intimidating at first, but once you're at it, it's not that difficult. Removing the crackshaft pulley is probably the hardest part if you don't have the tools, but having a 625lbs/in air gun will help immensely. OEM timing belt has pre-marked pulley indexes which make timing alignment a snap.
TriniLex
06-21-14 03:54 PM
canucklehe
02-16-13 09:30 AM
RSpi
15
11-14-12 06:50 PM
03LexIS300
IS - 1st Gen (2001-2005)
18
01-05-11 10:48 PM
dunahoo
Performance & Maintenance
45
01-30-10 09:47 AM
Quick Reply: Timing belt?
