Best mod I've done: One light touch to the turnsignal stalk ..3 or 5 Flashes
Hi,
I mounted this adjustable 3 or 5 flashes Turn Signal Relay, years ago in my 2008 LS 600 hL...the best, cheapest and simplest modification that can be done to most Lexi's
TIPTRONIC comfort flasher relay
Upgrade to the comfort flasher
1x light tap on the turn signal stalk once = 3x flash (or by moving the switch outside the box You can get optional 5x flash)
Available for these (European models)....but believe the flasher will work for other countries versions as well...
Lexus CT200H, from model year 2010
Lexus GS300/430, model year 1997-2005
Lexus GS300/430, model year 2005-2009
Lexus IS200/300, Typ XE1, model year 1998-2005
Lexus IS250/350, model year 2005-2009
Lexus IS-F, from model year 2007
Lexus LS430, from model year 2005
Lexus LS600H/600HL, Typ: USF 40/46 (will fit 2007-2009 at least..contact the seller for questions)
Lexus RX300/330/350, model year 2003-2007
Lexus RX450H, from model year 2009
In German language: http://www.pekatronic.de/product_inf...niversell.html
In English language: http://www.pekatronic.de/product_inf...versell.html&=
Price: Euro 35.95...roughly US $ 50 + freight
NEW price pr.06-12-18 Euro 39.95
Regards
Arvid
Regards
Arvid
Last edited by Arvid; 12-06-18 at 06:42 AM. Reason: misspelling..again :-( + Put in link in for details in english language
How to connect it:
TIPTRONIC Blinker Relay, Standard Version.
Information for Lexus LS600h/600hL, Type USF 40/46
Advice: The ECU box You will find beside the Fusebox under the Driverside Instrumentboard.
For the 2007-2010 Models:
(wires coming from the Pekatronic box in LARGE letters)
BLACK KL-31 to KL-31 Earth, A good earthing point
RED KL+15 to Pink, Pin 11, 28 Pol. Contact in the ECU unit
WHITE to Isolate this wire
GREEN KL+49right to Yellow, Pin 21, 30 Pol. Grey contact in Fusebox
BLUE KL+49left to Green, Pin 22, 30 Pol. Grey contact in Fusebox
YELLOW Blinker Signal Impulse to KL-31 Earth
BROWN Impulse Right to Yellow, on the Blinker stalk
GREY Impulse Left to Green, on the Blinker stalk
If these connections and colors are the same as mine..You should be good to go :-)
Regards
Arvid
Regards
Arvid
Yes it is that simple...and to change from 3 to 5 signals, just move the small connector outside the Pekatronic box, from left to right...I enclose the PDF instructions:1 for the LS 600 and 1 for the rest of the Lexus models (in German language)
for napstermik: They might also have it for Subaru...just ask them :-)
Here is a link to the company for those just reading english:-) :
Regards
Arvid
The enclosed pdf file: Tiptronic-Blinkrelais_3292_Lexus.pdf
will tell You where to connet the unit to most Lexus models :
The first one is for the LS600..460 too ??:
Regards
Arvid
Shipping to USA......
Contact Info:
Online here (in English language) : http://www.pekatronic.de/shop_content.php?coID=7
or
Ms. Kirsten Krohn
PEKATRONIC Alarmsysteme
Garstedter Weg 21b
D-25474 Hasloh
Germany
Phone +49 (0)4106 4041
Fax +49 (0)4106 4043
e-mail: info@autoalarm24.de
www.pekatronic.de
Arvid
3 or 5 blink by just touching the signal stalk
...I bump it up for newer members ..hope that is OK :-)
New price pr.06.12.18 Euro 39.95
