HID install for 2000 LX470 help needed
Hello,
I am in need to desperate help. I had purchased the HID kit from HID Extra and I looked at the harness of the headlights of my car and I cant seem to understand how they should connect? It looks like the wiring harness provided does not fit my car's wiring harness. I am attaching pictures I took. The harness coming from my car directly seems to have the male metal prongs in a horizontal position while the female end of the kit harness is in a vertical orientation. Can someone please let me know how I should connect this?
This is the harness connector from my car:
This is the harness connector to my OEM lightbulb:
This is the harness connector from HID Extra kit which I think goes to the ballast?
and this is what I got from the HID Extra kit. Am I missing something or some kind of different harness?
Or am I connecting something wrong?
Your help will be greatly appreciated it.
Thank you
Thank you
Look like your oem has an un-common wire harness. My suggestion is to cut the oem female connector in pic#2. Also, cut the red and black wires in pic#4 where you marked with the yellow question mark. Splice and connect the wires together to create a new female connector which you will connect to your oem male connector in pic#1.
And yes, the hid kit's female connector in pic#3 goes into the ballast's male connector shown in pic#4. Good luck.
Also, be sure you get the polarity correctly. I believe the the green wire is positive and black wire is negative/ground. So, connect the oem green wire to hid kit's red wire, and oem black wire to kit's black wire.
To rgarjr,
Its a H1 bulb. Thanks!
To jvxdriver,
Thanks for the tip, I also emailed the company I bought it from so hopefully they have an adapter or some other solution than cutting my OEM wires since I dont want to lose the ability to switch back to regular halogens if required.
But definitely thanks for your response, I appreciate it!
To jvxdriver,
