Finally installed the chrome 'Angel Eye' Headlamps
Old 11-02-07, 06:02 PM
  #31
PHML
Master Thread Closer!!
PHML's Avatar
Looks sweet...I would buy these.
Old 11-02-07, 08:11 PM
  #32
Olu
Olu's Avatar
Okay night time shots.
I didn't feel like looking for a nice solid white wall, so I started with my garage.
Disclaimer**
1. The shields on these projectors are shaped to create a sudden rise to the right side. This is aimed off to the side of the road and is actually great for street signs
2. I haven't aimed these lights properly. I aimed the drivers side way to the left in an attempt to widen the beam. This causes the right sided rise to be closer to the center (see last image). Even as is, it is off to the right on cars in front of me and does not light up the cars interior in front of me.
Here they are
I do need to do something about those fog lights.
Old 11-03-07, 03:38 AM
  #33
LexXxuS101
LexXxuS101's Avatar
interesting........i like it kinda...how wide is a beam?......PLS more night picsss!!!.....
Old 11-03-07, 05:01 AM
  #34
TonY_G
TonY_G's Avatar
how wide is the shroud around the projector housing? end to end?
how wide is the projector itself? about 2''? or more?
im pretty sure the E46/TT projectors will bolt up with very little modification,
but im not sure about S2k or TSX projectors, i think they are about 3'' or so
Old 11-03-07, 05:57 AM
  #35
LexFather
Guest
Posts: n/a
Thank you for sharing!!!
Old 11-03-07, 08:08 AM
  #36
olddog
olddog's Avatar
damn,
thats not bad output at all.
nice.
more pics would be great. thanks alot.
try messing around with the way the bulb sits in the housing. cos that greatly affects the beam pattern.
not bad at all.
Old 11-03-07, 08:53 AM
  #37
Seize
Loves Snickerdoodles!
Seize's Avatar
Looks nice
Old 11-03-07, 09:02 AM
  #38
gsCrazy
gsCrazy's Avatar
do you lose the lights in the high beam portion when you have the low beams on?
Old 11-03-07, 09:26 AM
  #39
Olu
Olu's Avatar
Next time I take the lights out I will measure the projectors and play with how the bulbs sit. I do think the output would improve with the proper bulbs.
If you're referrong to the wedge bulb than yes. It's either the halos or nothing. It seems like this would be easy to modify since there is a hole in the same location as the OEM wedge bulb is. I may play with it in the future but not now.
Old 11-03-07, 11:17 AM
  #40
PHML
PHML's Avatar
Thanks for the pics.
So the wedge bulb socket plugs directly to the Halos? No modification needed?
How is adjusting the low and high beams...same like the OEM units?
Thanks!
Pete
Old 11-03-07, 05:07 PM
  #41
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
they turned out pretty good against the GS.. Not bad for a ebay item..
Old 11-03-07, 05:19 PM
  #42
Olu
Olu's Avatar
The socket for the wires exist, but they hook up directly to the halos. You'd have to either remove the halos to expose the hole. You might be able to move the halo aside or cut a hole through it, but it's not going to be a simple plug and play for the wedge light.
Thanks!
Pete
Adjustments are the same as OEM. They don't seem to move as much as the OEMs did. They require a lot more turns to move a smaller distance.
Old 11-04-07, 12:13 AM
  #43
PHML
PHML's Avatar
Is there a hole on the chrome side where the wedge bulb was? Or are you referring to a hole on the backside of the unit?
Pete
Old 11-04-07, 06:46 AM
  #44
Olu
Olu's Avatar
Pete
There's got to be a hole because the wires go through to the halos. I can't tell how big it is on the chrome side without removing the lights. I'll probably take the drivers side light out next week to play with the shields and take pictures of some of the other request.
Cheers
Old 11-05-07, 05:49 PM
  #45
ocean350
ocean350's Avatar
swEEEEEEEEEEEEEEEEEEEEEEET!
Quick Reply: Finally installed the chrome 'Angel Eye' Headlamps
