96 es300 Climate Control Bulbs Info
Ok so here we go:
Notice the missing lights behind the temp ****? Well lexus said its a bad circuit. I agreed, the circuit that was bad is called a BULB. The pic above shows the pics after i pulled the color nipples off the stock 84999-60440 bulbs(qty3).(i have since put it back to stock.
84999-60430 (temp **** lights qty2)
84999-60440 (highlights for climate control, images of defroster, ect)
Those are the 2 part numbers. they have blue color nipples on them stock. if you pull them off they will look almost a peach color.(you can see that in the pics above)
