Fog Lights on sc400
Fog Lights on sc400
My Passenger side Fog light is out, i have a replacement Blub, but no idea on how to access the Light , any instructions would be greatly appreciated !!!!!!
Unscrew the underside cover beneath the foglight. They are 10mm hexnut. Unscrew enough of these screws to where you can easily access the foglight assembly from behind.
The fog bulbs are easier installed for first-timers while dettached from the car.
There are three bolts that hold the foglight assembly in. If I remember correctly, it goes two on the back and one on the top.
Once these are loose, disconnect the wiring harness on the back and slide the fog assembly forward. .
There is a black cap on the back that seals the assembly. Quarter turn left and pull out. There is a wire attached to it. It's a disconnect so pull it free.
You will see a bent wire, like a paperclip. This is a spring used to hold the bulb in. Unlatch the spring and the bulb comes free.
When you install the bulb, make sure you have no fingerprints or skin oil on it, otherwise it will burn out prematurely.
Good luck!
Good luck!
nfordhk
SC- 1st Gen (1992-2000)
08-14-09 06:02 PM
