- any discount codes from Tire Rack to CL members?
- 17" tires
- need help with sidewalls and stretching
- 235/35/20 Nittos
- tire size for 20s, will this work for me...
- Damni, tire problems here
- Sumitomo HTR IIIs on IS350
- New MODULARE WHEELS Models - M8 / M9 / M10
- Tire set up advice needed
- Hub Centric Ring not for OEM wheel? Help please....
- Help: its vibrating.
- Photoshoot of forged and 1 Piece Wheels, 56K NO WAY
- what other tires are good for stretching?
- Just weighed my wheels.
- Converting PCD
- 245 vs 225
- Tires for SC300
- Web based Offset Calculator. Please confirm Accuracy!
- Toyo T1R
- 350Z 35th Anniversary wheel hub bore size?
- New Tires, Need Expert Suggestions !!
- Yokohama Geolander
- Wheel Rechrome?
- 245/35/20, which offset?
- 2008 Dub Show Miami, Sevas Wheels
- Tire Fitment question
- Question about fitting
- ADR vs Maxxim
- Calling for all LS owners w/ 19"+ rims
- General Exclaim UHP, back ordered?
- 245/35/20 Nitto vs Falken problem
- 20" Tire Fitment for '00 gs300
- Yokohama S Drives
- what's your PSI?
- Mixed-set tires
- New wheels for the SC
- Tire Noob questions
- Vossen Wheels info
- Goodyear for RX300?
- Problem with Supra TT fit on my sc4
- Good wheel adapters?
- SC300 tire question
- Nexum tires any good?
- Front and Rear Different Tires question!!
- Spacer question
- RFT Tires Front, NON-RFT Rears
- Help me decide..
- Best tire for ride quality and comfort
- Is 205/45/R17 fine for a 17x7 wheel?
- iForged Neo / flat black face / gold lip
- Amistad Wheels Size
- Tire Sizing Question.
- VOLK's GT-V TPMS
- powdercoating oem wheels
- 5x115 wheel debate
- best place to buy toyo t1r's??
- stock wheel size?
- Rubbing Tires.. Dangerous??
- Want 2 know the correct backspacing for 20s on my 2002 GS300
- 18" 350Z rims on the IS300
- Need An Opinion On Winter Tires
- Difference between CrossDrilled & Sloted Rotors
- Falken FK-452 tires
- Hubcentric rings for project kics 10mm spacers
- IS250 Step Down to 17" Rims
- Ichiba Spacers - not impressed...
- Spline Lug nuts For Donz Columbo
- WORK VS-XX Question
- will these offset work for 2nd gen GS???
- Ronal USA ceasing retail distribution in the US
- What is the difference in strength 22's 3 pcs Vs 22's 1 pc?
- Maya rims Mercedes bolt pattern
- Need some hub centric rings
- Questions about Wheel Studs....
- Will this fit 01 GS430
- info on 245 on a 8" rim
- iForged wheels?
- Work Meister S1
- Wheel Adapter with studs????
- '07 IS250 Replacement Tires
- Will 275/40/18 look okay?
- Tire, Brake, & Spacer Question
- Blown Tire....
- Help Which Tires ????? Best!!
- Which tires best!!
- Is-f
- Looking for feedback on Bridgestone Turanza Serenity
- Center Caps Questions
- Purchase a wheel $$$$$$$$$$$$
- Tire repair question
- Best tires?
- Official: Post your tire pressure
- tire sizes?
- 11" Rear Rim
- Toyo Proxes R888
- 19 inch rear tires size for 2nd gen GS
- Nexen n3000??
- Tire Question
- Need some info
- tire size on stock 06 sc430
- G-Spyder
- Worst tire thread!
- Nitto Neo Gens?
- 19" Axis Hiro's on my GS400
- whell questions...is350
- just told i need pacers to fit rim. help !!
- Yokohama Advan S.4. Sizes attn:sktn77a
- gs350 awd + nf210 + 20"x9 all around custom off set + what tire size? Please help!!!
- Tire help... Toyo Proxes T1R compared to stock Turanza
- Volk TE37 time attack for IS350?
- Opinions on IS250/350 Rims for 2nd Gen GS??
- 01-03 LS 430 wheels?
- OEM Size Tires
- Which Falkens for an SC430
- What size tires do i need to make these fit?
- offset question
- Road force balance
- 20's on 08 IS350
- What size and brand low pro summer tire on 18x7? GS430 dropped..
- Racing Sparco NS6 help
- 20x8.5 ET15 on ES330
- Cheap BBK? Xendo?
- 90 lexus aftermarket rims ls400
- what's the cheapest you can get me..
- Anyone use H-rated tires?
- Torquing wheel lugs
- Wheel Lip Question - Please help
- Toyo Winter Tire Questions...
- tpms sensors when changing wheels
- question on work emotion kai wheels is250
- 'Offset' Explanation
- Rays Lug Nuts/ H&R Spacers
- fk452 sidewall height.. random question.
- Locking lug question
- Best 19" Tire Size for Optimal Comfort for the IS250?
- need advice on tires for my 08 GS350
- A pop on the tire, need help, :(
- Where to find these wheels used or Replica
- what wheels?
- Introducing our New Championship 5, 56K Beware
- Replacement Tires for 07 ES350
- Safe to drive on patched tire?
- trazano n7000 review???
- Tire rack has SSR GT3's on closeout
- Want to put wider tires on IS-F
- DO 10mm spacers require longer studs?
- Problem after tire rotation???
- Veloche Wheel Question
- tire wheel question..
- Tire question
- Goodyear F1 All Seasons
- Would this be too aggressive for a SC430?
- Fat set up or not - conflicting info
- Proud Sponsor of Club Lexus, Sevas Wheels Inc.
- iforged daytona's price check
- DYI Fender Rolling Video
- What size spacer to go with? RX330 wheels on a GS430..
- How long till brakes performs at optimal performance?
- is it possible....
- Suggestions for a '94 ES??
- help me with offsets??
- what tires should i get
- Help me choose a tire
- Rims with lips easier to bend?
- From 225/50/17 tires to 245/45/17
- wheels peeling already? Donz montanas
- TC Sportline wheel spacers
- Wheels used in Miami VIce?
- Stock Sc300 rim cap removal?!!
- Brakes for least Warp chance.
- MRR Wheels need feedbacks
- Rays R.E.M. Roga for IS350
- Need Help/Picture - Tire & Wheel
- AUTOMONDE FORGED Wheels
- Need Help! will this fit?
- g35 Rays
- 19" for IS250 awd. Please help
- Will 17" wheels from an '01 GS430 fit an '06 GS 430?
- 245/40/17's ok on 17x8 inch wheels???
- Ride Quality
- Need help from Gettins owners or those in the know
- New is250! I need bigger wheels.
- Probably an easy answer. 94GS300
- Optimal wheels to the rear axle on the Lexus SC 300
- questions on wheel specs for ls 430
- about to buy 19's....Advise first please?
- Michelin Pilot Sports A/S
- Polish Lip Question
- Brandon, Need advice on an aggressive tire setup.
- On Vaca
- So Discount Tires wanted $40 to Patch my Tire LOL
- Need help with my GS350.
- ISP wheels
- Will 2006 G35 wheels fit on an SC300?
- 18x8 - What size tire?
- Brandon,any Bridgestone rebate or sales coming soon at TR?
- 1 more volksgtn rim
- Confused
- Fixing Curbed Rims w/ Dremel tool????
- AZA Wheels, What's the deal?
- Rim Rash So. Fl
- cant find offset
- tire recomendations for ls400?
- Will this 19" fits on IS250RWD?
- Will 255/40/18 & 285/35/18 Tires work on GS400?
- Gold caliper paint
- GS Chrome Wheels
- Question about wheels
- What brake fluid to use?
- help gs bolt pattern question
- 2GS 245/45-17 dropped with 20mm or 25mm spacer
- What Is The Best Offset For 2GS w/ 19x9 or 8.5f & 19x10r?
- 18" Tire load index
- tire pessure question
- Tell me the Cons of Adapters
- Stretching Safety...
- How to remove chrome from stock wheels?
- if air is leaking from.....
- New Tire Help
- The Pros and Cons of 19inch wheels vs 18inch wheels
- IS250 What wheels are these?
- Tire size for IS350 with 19" wheels?
- Staggered Setup Question
- Pic request 215/35/19
- What tire sizesss for 19x10 +41 (fat setup)
- New Tire Question
- Help with spacers
- What size tires do I need?
- Michelin Pilot Sport vs. Pilot Sport PS2
- Who makes 10mm spacers?
- Does anyone know where I can get some 20 inch white wall tires???
- Tires for 1993 GS 300
- what color is this.
- lug nut locks oem?
- New ZONE FORGED WHEEL : Z10
- Think my rotors are warped
- tire rack suggestion for stock 17s
- Harsh Ride
- Dunlops on my new LX570
- Help identifying rims
- Help finding rims & tires
- lighweight lug nuts?
- wheel fitment on 1gen ls400? 18x9.5 +35mm
- Continental ContiExtreme Contact
- Bridgestone vs Falken A/S for So Cal rain
- Gettin' some new shoes!!
- Tires - Soft AND Quiet?
- Winter tires anyone? Choosing between Blizzak WS60 and Revo 1
- A/S Tire suggestions - 2005 ES
- Will these fit????
