Android in RC using AV jack
In my previous car (Toyota GT86) have replaced the OEM headunit with an Android bought on Chinese market. It was usefull particularly to use Torque Pro and read in live all the engine informations.
Now I would like to have the same things on my RC200T but do not wish to change the original equipment. Fortunately the car is equipped with an AV jack. Thus, I decided to use this connection to obtain the intended goal. I bought an Android TV box, make the correct wiring plugs, change the launcher to have a most easy use and go on.
Below some views of the system, it remain the modification of the brake wiring to allow a functionning during driving. (not difficult but the time ...)
Hope this will give idea to other members.
The equipment in the central compartment
Torque Pro main page
Torque in action
Visual from driving position, good visibility
The launcher main page
My phone with Miracast
GooglePlay with the wifi connection of the box
In fact you can use the box as a phone with all the Android options and applications. You can also see movies (it is not reasonable during driving...) music and so on.
Torque in action
For the equipments, regarding the TV box I took the T95N as is originaly fitted with Wifi and Bluetooth. On the other had is smallest that other in the market 9.5 cm X 9.5 cm which is perfect for the central compartment. A substential advantage is the cost which is under the 40$ an exemple but you can found it in other shop or Ebay ;http://www.banggood.com/fr/T95N-Mini...p-1057606.html
For the cable, the jack is a 4 points but the connections are not standard. You have to be check carefully the various connections otherwise you will not obtain a result. In fact for the Lexus side you have the details in the car book but for the T95N you have to check. With the herebelow schematic I confirm that for Lexus (RC) side it is the "Samsung" connection and for the T95N it is "Apple
iBook,..) It is in French but easly understandable.....
Personnaly I make my own cable with only the video as for my use I don't need the audio and the cable is reduced to 20cm.To a normal use you can use the cables with the RCA connectors like
http://www.ebay.fr/itm/3-5mm-Jack-Fi...oAAOSw41xXOZxX and http://www.ebay.fr/itm/3-5mm-Jack-Fi...oAAOSw41xXOZxX, just control carefully the connection between the jack and the RCA accordingly with the previous information as the collors are differents.The main problem is that the cables are rather long.
For the power you can use any cable connected to a 5v adapteur. I did not try direct on the USB connector as I use same for my music and are not free.
Regarding the system itself, the box is principally dedicated for the TV and the main page is mad for. I prefered a standard screen and I installed an other launcher. I took one as simple as possible "Smart Launcher" easy and not complicated.I,of course add other application to facilitate the use, "Shutdown" allowing easy switch off, "NOMone Resolution Changer" This application is intended to change your device resolution and density which is important to a correct visibility on the car sceen. For the 7" screen in the RC, a good setting is 1024x576 - 240DPI. Of course you can try other settings but it is difficult to find a good one. Try this and you will have the result as previousely showed.You can add all applications you may need as this box as important memory and is already rooted.Don't forget "Torque Pro", of course;-) and an ELM327 plug V1.5 (forget the version 2.1 as you risk to encounterd numerous connection problem) For my side I have this one http://www.dx.com/p/elm327-v1-5-obdi...ite-12v-149344 which is interesting with is power switch allowing remaining in place with no power when not used.
I hope to have given sufficient informations and remain
Oupss, I forget the mouse, I use this http://www.banggood.com/fr/BESTRUNNE...p-1014813.html cheap, slight and sufficient for change application. In fact with the mouse on the armrest you can do everything.
kphu
GX - 1st Gen (2003-2009)
15
08-14-18 10:03 AM
Joeb427
03-29-11 02:25 PM
