Vaistech SL2i-UP Install Issue on 2007 RX 350
Old 10-12-14, 06:10 AM
TheSchlaf
TheSchlaf's Avatar
Default Vaistech SL2i-UP Install Issue on 2007 RX 350
I have a 2007 RX 350 with Mark Levinson. A few weeks ago I installed a Vaistech SL2i-UP and the unit worked great. Then one day, I took my iPod out of the car to sync it with iTunes. In the meantime, I was using the radio and CD player. After my iPod synced with iTunes, I reconnected it to the SL2i-UP unit and it worked. However, now I cannot use AM, FM, or the CD player on the radio. I have disconnected the car battery and reconnected it to clear out any settings that may have gotten screwed up, but the tuner nor CD player function. I also cannot switch to the XM tuner. Does anyone have any insight as to what may be happening? Thanks.
Old 10-13-14, 11:26 AM
rominl
exclusive matchup
rominl's Avatar
have you tried disconnecting the sl2i-up harness (to the unit) and see if the radio works again?
Old 10-16-14, 06:29 PM
TheSchlaf
TheSchlaf's Avatar
I did. The CD player, AM, and FM tuners don't work even without the vaistech harness and module installed.
Old 10-17-14, 01:37 PM
rominl
exclusive matchup
rominl's Avatar
if the system doesn't play even without the vaistech connected, i hate to say, but it sounds like the head unit is having problems from my experience the vaistech is a passive device, in a sense that if there is addressing conflict, once you remove the brain the factory system should function.
Old 10-18-14, 07:56 AM
TheSchlaf
TheSchlaf's Avatar
Thanks for the reply. I ordered a new ML headunit from Ebay. I'll see if that resolves my issue.
Old 10-25-14, 04:28 PM
TheSchlaf
TheSchlaf's Avatar
Just a follow up. I purchased a used ML head unit from EBay out of a 2008 Lexus RX 350 and the tuner and CD player works now. I have grounded the SL2i-UP to the chassis now as well. Not sure if the Vaistech caused the issue or if it was the head unit's time to go.
Old 10-27-14, 11:03 AM
rominl
exclusive matchup
rominl's Avatar
good to know! yeah probably not a bad idea to ground the box as well. hopefully everything is well from now on!
wmbinford
11-27-17 08:08 AM
TheSchlaf
10-12-14 09:09 AM
Sailor23
12-17-12 07:18 AM
thepro2cer
14
07-26-07 12:36 PM
thepro2cer
08-17-06 12:29 PM
Quick Reply: Vaistech SL2i-UP Install Issue on 2007 RX 350
