Lexus IS F - Adding a Better Sub Stage (Illusion Audio / Mosconi) *Build Log*
Old 08-10-14, 09:07 PM
shahir18
shahir18's Avatar
Default Lexus IS F - Adding a Better Sub Stage (Illusion Audio / Mosconi) *Build Log*
I have a 2012 Lexus IS F with the Mark Levinson sound system package. I like the clarity and detail of the factory given ML speakers. The mids and highs are great, but it lacks in the low end bass. So I wanted to add a better balanced subwoofer stage and to remove the factory subwoofer. The objective of the install is to make it stealthy, factory looking, simple, and clean.
My Equipment:
illusion Audio Carbon C12
Mosconi AS 200.2
Mosconi RTC-MOS
Gladen ZeroLine RCA
AudioControl LC2i
NVX XAPK4 Amp Kit
KnuKonceptz Karma Speaker Wire
4080/Boxology Custom Sealed Enclosure (1.35 cubic ft)
First thing was to remove the spare, use factory mounting locations (no drilling)
Installed the remote bass **** control to the stock empty slot on the right of the steering area
The factory accessory mat does lay perfectly over the false floor, becomes flushed and stealthy
The subwoofer blends very well and smooth - never over bearing to the stock speakers. It is very accurate, plays low, and can get loud... Overall I am happy with the result.
Old 08-12-14, 05:42 PM
ISFpat
ISFpat's Avatar
Very well executed.. how much did this all run you approximately?
Old 08-12-14, 07:54 PM
shahir18
shahir18's Avatar
Thanks, a little over $2k in just equipment
Old 08-13-14, 08:20 PM
Kalel250
Kalel250's Avatar
wow. very clean install!
Old 02-07-15, 10:00 AM
Jbreezie
Jbreezie's Avatar
clean setup! giving me ideas
Old 02-07-15, 05:08 PM
Enough
Enough's Avatar
Wow, outstanding super professional fabrication. Did you pull a high level signal from the OEM ML sub in the rear deck? Also where did you run your positive cable from? (battery).
Old 02-08-15, 05:46 AM
darylrsv4
darylrsv4's Avatar
Nice job man.
Old 02-08-15, 07:33 AM
ChickenIS
ChickenIS's Avatar
This is very nice. Great job.
shahir18
IS F (2008-2014)
28
03-25-15 10:22 AM
ereyes430
05-29-12 12:13 PM
flipicanez
07-18-10 10:47 AM
brianphi
03-26-08 10:52 AM
jadeboy
07-23-07 12:22 PM
Quick Reply: Lexus IS F - Adding a Better Sub Stage (Illusion Audio / Mosconi) *Build Log*
