Aftermarket amp and speakers helpp!!!
Old 09-03-12, 11:18 AM
mcsddd
mcsddd's Avatar
Default Aftermarket amp and speakers helpp!!!
I want to upgrade my speakers to aftermarket speakers and amplify them with an aftermarket amp. My problem is the factory amplifier. If the speaker wires are going straight to my amp would i need a line out converter for the rcas? I want to keep the factory head unit. ive also seen bypassing the factory amp. what is the reasoning for that?. is that what i need to do? do i need a wiring harness? im confused and have been searching the forum but it hasnt really helped. Can someone help me out please. Thank you
1998 Lexus Gs400 with pioneer system
Old 09-03-12, 11:50 AM
mcsddd
mcsddd's Avatar
im guessing i just need a line out converter and a speaker harness
Old 09-03-12, 11:58 AM
mcsddd
mcsddd's Avatar
not even a harness just a line out converter
Old 09-03-12, 04:39 PM
Shibumi1
Shibumi1's Avatar
i'd suggest an audio control piece over a simple line convertor.. they increase signal voltage up to 8volts so u can keep amp gains down..less distortion, cleaner signal.. the LCQ-1 (the 1 i own) even has an eq built in... awesome for the limited eq settings in the oem head units.. in this set up u can either keep the factory amp (what i suggest) an run the processors after the amp .. then thru the processor to your after market amp an out to your speakers... or you can take the input from the oem h/u directly into the processor bypassing the oem amp and go to the aftermarket amp.. but the signal level will a lot lower than keeping the oem amp..also any processing in the the oem amp will be lost (mine has dolby thx that i'd hate to lose)..
Attached Thumbnails Aftermarket amp and speakers helpp!!!-audio-control-lcq-1.jpg   Aftermarket amp and speakers helpp!!!-audio-control-lc8i.jpg
Old 09-03-12, 07:54 PM
mcsddd
mcsddd's Avatar
so how would i run the processors after the amp? if there is a write-up to this and you know a link that would help a lot.
Old 09-14-12, 01:55 AM
Rozay604
Rozay604's Avatar
Theres better signal processor than audio control. i find that audio control can be a bit noisy. look into the jl clean sweep, audison bit one or even the jbl one.
sereousl
08-31-14 09:19 AM
rome58
12
08-12-12 04:32 PM
Emilaman
11-11-11 07:37 AM
Woody426
SC- 1st Gen (1992-2000)
08-02-11 03:32 PM
GFarra31
05-04-07 08:11 AM
Quick Reply: Aftermarket amp and speakers helpp!!!
