DIY ML Center channel replacement (04 GS)
Old 03-17-10, 09:42 AM
biggieTX
biggieTX's Avatar
Default DIY ML Center channel replacement (04 GS)
After searching around and learning that many folks have had problems with their front center channel speaker being blown. I thought it might be helpful to post some photos of how to remove the center speaker.
The primary problem removing the center channel (especially on my 6 year old GS) is that the plastic has become brittle from sitting in the sun. My first attempt to remove the front speaker grill resulted in the plastic breaking under pressure.
After that failed attempt I decided to remove the vents and attempt to free it up from under the dash instead of pulling it from the top side.
I removed the vents. They came out by simply prying gently with a small flat blade screwdriver.
Unhook the hazard and the clock
hazard connector on left and clock on right.
You can see the center speaker held from the bottom by three clips.
I then pinched the clips and attempted to gently slide out the grill assembly. There was a large amount of creaking and cracking no matter how gentle I was. The three clips ended up breaking off the grill.
I then removed the speaker connector
Here is a picture of the ML center speaker
I cannot stress enough how brittle the three clips were that were holding in the speaker. They almost crumble in your fingers.
They snapped off with barely any force applied to them. I expect this is the case with any of the older models. As the plastic ages in the sun it becomes very brittle.
I will be ordering a replacement grill and aftermarket center speaker to replace the blown stock model. I will update with more pictures when the project is complete.
Old 03-17-10, 10:29 AM
ntran18
ntran18's Avatar
Thanks for the pics. I am going to be working on the center speakers soon. What size is the speaker?
Old 03-17-10, 10:42 AM
sam430
sam430's Avatar
Please post the grill part# Also, would like to know the size of the speaker... I'm looking into putting 3.5" in it's place. It would be nice to get a far shot so I can figure out how to cut up the plastic to install that grill.
Old 03-17-10, 12:37 PM
biggieTX
biggieTX's Avatar
A far shot of the grill assembly or the hole in the dash?
Old 03-17-10, 02:47 PM
sam430
sam430's Avatar
The hole in the dash Thanks. btw, I posted some nice sub deals in deals page.
Old 03-17-10, 04:23 PM
Big Mack
Big Mack's Avatar
Wink
Link is broken, Sam. Here it's working.
Big Mack
Old 08-23-10, 05:49 PM
'99 SC 400
'99 SC 400's Avatar
Default Center speaker
Do you have an update? Where did you get the grill and speaker and there cost?
Old 08-24-10, 06:53 AM
Red Bully
Red Bully's Avatar
save your self the headache and get a right angle screw driver and just remove the speaker and not the grill
Old 09-03-10, 07:44 PM
biggieTX
biggieTX's Avatar
I need to track down an aftermarket replacement speaker. I found a thread a while back that gave some options but I have lost track of it.
Old 09-03-10, 09:54 PM
Percy
Moderator - Electronics Forum
Percy's Avatar
Wonder if a Dyn MD140 midrange would fit there...the ideas are churning!
Old 09-05-10, 06:11 PM
GS4_Fiend
GS4_Fiend's Avatar
Is it true that this speaker only works during radio mode?
Old 09-11-10, 12:44 PM
dungut
dungut's Avatar
No, it works on CD mode also. I have not tested it on tape or AM.
Old 04-30-11, 12:41 AM
sam430
sam430's Avatar
How big is the center channel? I have a 6.5" sitting under there and need to make an opening. This may do the job. Part number?
Old 07-11-11, 06:36 AM
jw11301
jw11301's Avatar
Default ML center channel speaker grill replacement
I need to just replace the grill since it cracked. Is there any particular reason I would need to remove the vents to remove it or will it come out from the top if I am not concerned with breaking the tabs?
Old 09-03-11, 05:12 AM
AirRideFan
AirRideFan's Avatar
First of all- My center channel speaker blew (I'm assuming the surround has separated, just like the OEM Mark Levinson 10" subwoofer's surround has, also)
THANK YOU SO MUCH for posting the pics though- that's a TREMENDOUS help.
I wanted to tell you that I bought a nice used replacement center channel ML speaker on ebay (It was like $60, shipped) That's where I'd recommend buying a new speaker.
What about that trim ring though... it that a SEPARATE part from the grill/speaker housing? I need a new one too.
Quick Reply: DIY ML Center channel replacement (04 GS)
