Drop-in subwoofer replacement/upgrade for IS350 with ML
Has anyone done this? I am wondering if there is a good subwoofer out there to replace the stock one that can simply be dropped into the stock location. One that is compatible fit wise as well as power-wise.
I've actually decided I am not going to do a "drop-in" install.
Instead, I am going to install a JL Audio 10" W6V2 subwoofer in a sealed enclosure powered by a JL Audio 250/1 amp. JL Audio sells this subwoofer in a pre-built enclosure that is VERY small. I will post pics once it's installed.
The only thing I am debating it whether or not to REMOVE the stock sub instead of just disconnecting it. I'll probably just leave it installed...
Lexs400
11-29-02 05:26 AM
