Dynaudio In An Sc400 Help!!!!
I have an SC400 and I would like to replace the rear subwoofer. I am going to go out and buy a dynaudio subwoofer 10''. Do I have do any modifying back there to the hole? Will it just drop in or should I have it professionally done? I know how to do all the wiring but I had modifying stuff. Let me know. My car is under gallery SC..... It is the blue/green SC with chromes.
I am going to go with the Diamond 10". I was told that this would probably work the best. They are much thinner from top to bottom for clearance in tight spots. Did you do a aftermarket radio? I have all my stuff waiting to be installed. If you do have a aftermarket radio, how did your install go. 92 SC400
I am keeping my stock pioneer/lexus head unit. I think the dashes look really cheap and undesirable if they are replaced. I have yet to see a radio application that looks as good as the stock. I am using line out converters and have added 2 amps. I have not done the install yet but it is pretty simple if I dont need to do a lot of custom work.
Dynaudio 10" or Diamond 10"? Which worked better? I removed my stock sub tonight without too much difficultly and now I need the upgrade. It looks from the specs that the Dynaudio 10" mounting holes will not line up. What modification is required?
Other sub comments?
Kevin
Other sub comments?
Kevin
t70 supra
07-11-07 10:12 PM
poutsa
05-07-07 04:58 PM
