12V power outlet. Please help !!!!
Old 04-03-15, 05:11 PM
aeggroup
aeggroup's Avatar
Default 12V power outlet. Please help !!!!
Hello All.
I'm trying to find 12V power outlet in my 2014 IS250. I have searched all interior and could not locate it anywhere. Do you guys know where it is ?
Thanks.
Old 04-03-15, 05:16 PM
4TehNguyen
4TehNguyen's Avatar
inside the armrest compartment
Old 04-03-15, 05:18 PM
Lindenlea
Lindenlea's Avatar
did you look under your armrest in the storage container?
Old 04-03-15, 05:47 PM
aeggroup
aeggroup's Avatar
Thank you guys for quick reply.
I looked there and could not see nothing there. All I see is USB port. Am I blind ? Are you guys sure it's there ?
Old 04-03-15, 06:03 PM
aeggroup
aeggroup's Avatar
Originally Posted by PatrixUSA
It's there, see image.
thank you so much for the picture. I'll check it out first thing tomorrow morning.
Old 05-16-17, 09:56 PM
nathantse
nathantse's Avatar
Sorry to revive an old thread.
But... how many 12v do we 3IS owners get in the car? The obvs one is the in the center arm rest. Is there any hidden ones?
Old 05-16-17, 10:07 PM
nathantse
nathantse's Avatar
Nope, just the one shown in post 5.
That sucks, the RX gets 4
Was thinking of using the 12v to power a dash cam..
Old 05-17-17, 12:27 AM
peteharvey
peteharvey's Avatar
I just use a two, three, or four way 12V socket adaptor etc, to power the front and rear dashcams simultaneously.
Old 05-17-17, 12:31 AM
nathantse
nathantse's Avatar
Seems cool, but this may be a stupid questions, but is this safe to use? I don't want my car to catch fire lmao.
Old 05-17-17, 01:02 AM
Matroushi
Matroushi's Avatar
So long you're not drawing a lot of current. If I'm not mistaken you'll blow the power socket fuse at 10 A.
Old 05-17-17, 06:02 AM
peteharvey
peteharvey's Avatar
Drawing directly from the car's lead acid battery, or the fuse box, can deliver a maximum output of something like 12V @ 7 Amps = 84 Watts, due to the natural internal resistance inside the PbSO4 battery.
The cigarette lighter socket in the car can normally deliver a maximum output of 12V at only 5 Amps = 60 Watts - if I'm not wrong.
Apparently, each single channel dashcam runs at only 5V and less than 0.5 Amps maximum draw, ie 2.5 Watts.
Thus two single channel dashcams runs at 5V and less than 1 Amp maximum draw, ie 5 Watts.
So it should be safe.
Old 05-17-17, 07:07 AM
LeapFrog
LeapFrog's Avatar
Drawing directly from the car's lead acid battery, or the fuse box, can deliver a maximum output of something like 12V @ 7 Amps = 84 Watts, due to the natural internal resistance inside the PbSO4 battery..
The maximum output at the terminals of a car's lead acid battery is dependent on the battery manufacturer's specifications and the condition of the battery - as well as ambient conditions.
Cite: https://www.carsdirect.com/car-maint...d-hour-ratings
Old 05-17-17, 11:04 AM
nathantse
nathantse's Avatar
Thanks! This seems like the easiest way to go. I'll look into buying something like this.
And just to be sure, the 12v port only works when ignition is on... so when I park my car, the dash cam will not be powered? Unless it has its own power source..?
Old 05-18-17, 02:01 PM
peteharvey
peteharvey's Avatar
Yes, the 12V cig lighter socket only works with the ignition on.
When you turn the ignition off, your dashcam will power off.
Old 08-28-23, 09:44 AM
little2576
little2576's Avatar
Default which fuse to replace for 12v power socket
If you blow your 12v socket fuse.....Can you tell me which fuse should be replaced ? Ive changed the p/outlet no.1 fuse which is a 15a but still no power, i also had the socket replaced with no luck.
Quick Reply: 12V power outlet. Please help !!!!
