Pressure points on plastic engine cover?
Took my engine cover off and now trying to snap it back on and I can't seem to find the points where it clicks back into place. The top middle has a latch but my bottom half especially the right side is loose and I can't figure out where the snap into place points are?
Any help is appreciated thanks!
First thing you need to do is to make sure that Engine Oil Cap is properly aligned to the hole that engine cover has, basically the cap should be accessible via the hole. Then just visually align the cover so that everything seems proper, for example "L" logo looks right to you etc. I am pretty sure after that you just simply press on the cover it snaps back into place. The easiest thing ever!
