Will these rims/tires fit?
Old 10-02-14, 03:41 PM
spiceboy23
spiceboy23's Avatar
Default Will these rims/tires fit?
Hi everyone,
Just purchased my IS350 a month ago. Loving it so far!
Winter is around the corner, and I have a set of winter rims/tires from my previous car. I am just wondering if they would fit onto the IS?
19x8.5 with 44mm offset
255/35 - R19 tires
Thank you for your help in advance.
Old 10-02-14, 04:53 PM
FSportDRM
FSportDRM's Avatar
I think you should fine. If anything compare it to the sizes and specs offered on tirerack. But i think thats a close to OEM specs
Old 10-03-14, 07:44 AM
spiceboy23
spiceboy23's Avatar
Thanks FSportDRM. Yes that's what I did and the sizes seem pretty close. I was hoping if any wheel specialist can confirm that.
Old 10-03-14, 09:32 AM
CJW
CJW's Avatar
255/35/19's will likely be too big (just under 4% error). Can't hurt to test fit them though as long as you can live with the minor speedo error and there is no rubbing. The rims are fine - though make sure if they are not from a Lexus/Toyota that you get the right hub ring.
ronnymo
ES - 5th Gen (2007-2012)
23
07-07-21 05:46 PM
JattLexus
06-28-17 06:45 PM
ExtrmeLex
12-01-12 07:03 PM
cards43am
SC- 1st Gen (1992-2000)
02-15-11 06:42 PM
killi101
Wheels, Tires & Brakes Forum
07-28-04 05:52 PM
Quick Reply: Will these rims/tires fit?
