Need a part number
Need a part number
Hello,
I have gotten into a small accident and it seems the passenger side rear door shell needs to be replaced. Other shops said that at least outer door skin must replaced. I tried to search the part(s) on sewell but cannot successfully locate it. Does anyone know the part number? I appreciate in advance. Pictures are attached.
Unfortunately you have a relatively complex repair. Bring it to a professional body shop and let them obtain the parts for you. If you want to know the cost of the door skin contact a Lexus dealer but the sill repair could be just as costly depending on how they approach it. Hopefully they can pull that sill and smooth it out with a liittle Bondo. If not then you are looking at some metal replacement which can be pretty expensive.
Thanks for your very reassuring post I talked to several body shops and all of them have a pretty good reputation in my area. They seemed to be very confident that the sill can be repaired without any issues. But I will talk to them once again about it since you mentioned that it can be a relatively complex repair.
I really don't want to buy it from a Lexus dealer or a body shop as they usually charge MSRP. I know Sewell has some good deals for CL members so if I knew the part number I could just order it online.
niteflite
03-26-10 07:50 PM
