Weak Headlamps and High-Beams. :|
Old 12-19-13, 11:30 AM
WhatIsUp
WhatIsUp's Avatar
Originally Posted by dbs600
I'm not sure. I have a 2014 Lexus IS350 AWD F Sport w/ Nav and BSM.
How do I find out? Didn't know we could chose between LED's and HID's.
http://www.washingtonpost.com/rf/ima...carsdcom_3.jpg
The top photo shows an HID-equipped headlight while the bottom photo shows an LED-equipped headlight.
Old 12-19-13, 11:33 AM
dbs600
dbs600's Avatar
Thanks; bottom pictures it is...
Old 12-19-13, 11:54 AM
jcheng
jcheng's Avatar
To those of you with the LED headlights, is the cutoff wrong?
the driver side peak coincides with the lower portion of the passenger.
I always thought the driver upper cutoff with level off with the passenger upper cutoff making it one straight cutoff.
I turned on the high beams and they are level? Any ideas?
Old 12-20-18, 07:03 AM
Peaved73
Peaved73's Avatar
Angry low beams
Maybe I'm crazy but on my 2018 ES300H the low beams light about 120 feet ahead and the auto high beams are coming on very frequently. From what all i read the low beams should light almost 300 feet so you can stop at 55 mph before hitting an object. I have a 2019 Toyota Camry ESE that has low beams that light at least double the distance of my 2018 ES300H. I'm sure the type of low beams is the same. My dealer says they are adjusted correctly and cannot go out and further. That's no more than for white lane lines on my car which is 120 feet. I feel something is wrong especially with my high beams going on and off frequently on the ES300H. On the same roads my 2019 Camry XSE high beams do not go on at all and the low beams are sufficient. I expect to be stopped by police for flashing high beams. I need to see the road in front of me. The Insurance Institute for Highway Safety will do nothing about it though they do report many new auto low beams are insufficient. I have on file a complaint with the NHTSA. I had a dealer loaner 2019 IS for two days and those low beams were also out double the distance of myES300H. I did ask the dealer why the right side headlight on the IS lights out further than the left and the dealer stated" It was purposely made that way"????
Old 12-20-18, 07:34 AM
E46CT
E46CT's Avatar
Received 2,212 Likes on 1,656 Posts
19 Camry=new gen stuff.
18 ES=old gen stuff.
Most of the 19 cars have updated projection systems. you just own a car with last gen headlights. the redesign (7ES) should have redesigned projection.
Old 12-20-18, 07:36 AM
E46CT
E46CT's Avatar
For anyone wondering--Normal.
LED projection typically does not get as sharp a cutoff as HID. It's a very fuzzy hazy curved cutoff with lots of soft dispersion and rainbow effects.
Old 12-20-18, 07:41 AM
Peaved73
Peaved73's Avatar
Angry Low beams
That doesn’t explain the distance being 120 feet instead of 300 feet.
Old 02-09-20, 07:42 AM
Peaved73
Peaved73's Avatar
Talking Weak headlights
I have solved my 2018;Lexus ES 300H very poor headlight illumination. It’s 2-3 white middle road linesor no better than 150 feet.
I discover that driving entirely using high beams at night gives me at least three times the illumination and much better side illumination.
stange as it may seem no driving coming towards my Lexus has flashed their high beams to show my high beams are in their vision. This is over the past month and hundreds have care have driven towards me and even those in front of me.
my only conclusion is that my low beams are really my daylight running lights and my high beams are really my regular lights thus I really do not have a high beam setting.
Lexus dealers and Lexus corporate states nothing can be done as nothing is wrong. Just perhaps a manufacturers defect in the setting of the light holders as they are the self adjusting type.
Perhaps after I return my leased vehicle someone in the vast country will become aware of a inherent problem with the headlights.
i am now completely satisfied with my use of high beams all the time at night and they apparently do not cause problems with other drivers.
Old 05-20-24, 04:15 PM
venera
10th Gear
venera's Avatar
Originally Posted by IS35OF
I have read many times that the LED headlights fitted to US vehicles have less light output to those UK/JDM/Australian etc. vehicles fitted with the HID Xenon lights.
I would of thought LED would be better being newer technology, but if that's the case, I'm glad our Australian models come with Xenons. LED headlights are only available on the hybrid IS here as far as I know (obviously for power consumption reasons I assume.)
Now sure of its possible to upgrade LED headlights??
If you add option for lane assist & IHB they install a camera near rain sensor. This camera is used for the lane assist and intelligent high beam. They will also switch out the HID to LED as only the LED version is IHB compatible.
Restomod
06-23-17 01:22 PM
bmwlexus09
RX - 3rd Gen (2010-2015)
06-30-16 11:08 AM
donaldp
RC - 1st Gen (2015-present)
11-24-14 07:14 AM
djyoshi626
CT 200h Model (2011-2017)
47
04-23-12 10:13 AM
gandro
09-26-06 09:29 PM
Quick Reply: Weak Headlamps and High-Beams. :|
