Best way to jack the car?
Old 09-14-13, 04:43 PM
Dark9t316
Dark9t316's Avatar
I damaged the right floor panel, went over a curb so I need to jack the car to inspect and possibly replace the panel. I'm not really sure where to place the jack stand without damaging the car, any suggestions?
Old 09-14-13, 05:08 PM
Hoovey689
Hoovey689's Avatar
roughly 4inches inward from the side rocker panels is a skinny black metal rail. Iirc there's even tiny grooves. Anyway that's where you can jack the car from
Zlots
Zlots's Avatar
Page 400 of the manual shows the jack points.
Page 480 shows those notched rails.
Old 09-14-13, 05:27 PM
Dark9t316
Dark9t316's Avatar
That's actually where I jack the car (see pic
) but then I don't know where to put the stand. My jack doesn't quite reach the jack point on page 400.
Old 09-14-13, 05:32 PM
Hoovey689
Hoovey689's Avatar
Originally Posted by Dark9t316
That's actually where I jack the car (see pic) but then I don't know where to put the stand. My jack doesn't quite reach the jack point on page 400.
Usually I just put the stand right next to the jack on the same rail. Never had any issues
Of course I invested in a low profile jack which makes it a breeze
Old 09-14-13, 06:32 PM
BarrettF77
BarrettF77's Avatar
There are actually arrows pointing inwards at the center of the jack point. All Lexus's cars should have them under there. See the above picture already posted and you'll see what I'm referencing.
Old 09-14-13, 08:08 PM
Dark9t316
Dark9t316's Avatar
There's not enough room on the same rail, if I jack the rear side, then I can only put the stand on the front side. Since I already have a jack, I'm thinking maybe I should invest in wheel ramps?
Old 09-14-13, 08:15 PM
Dark9t316
Dark9t316's Avatar
Yea that's where I'm jacking the car. Another general challenge is that I noticed that the rail won't touch the arm's bottom part of the 'V'. The top of the 'V' will be holding up the car instead, but if you see in this picture, it is touching plastic! I know as soon as the car sits on the stand, the plastic will crack. I've never had these issues with Toyota or Honda before.
Old 09-14-13, 08:16 PM
Dark9t316
Dark9t316's Avatar
Forgot the pic earlier
Old 12-07-13, 05:11 AM
SonyHome
SonyHome's Avatar
Attachment 297770
Were you able to figure this out? Do we need to buy special adapter for jack and stands to make this work?
In the manual it states to put the floor jacks either on the front or rear but I just want to be able to swap my wheels lifting little from each corner.
Old 12-07-13, 02:55 PM
Dawa
Dawa's Avatar
you SHOULD buy an adapter for the jackstands (if you already have jackstands) OR find the jackstands with the notches already in them to keep from damaging/folding over that pinch/seam.
that pinch/seam is used for the scissor jack when youre on the side of the road with a flat/similar so if you damage it you wont be able to use the scissor jack safely
i dont have the photo for your car, but this illustration hepls
Old 12-07-13, 11:09 PM
semoquer
semoquer's Avatar
any suggestions for jack stand adapters?
Old 12-08-13, 08:31 AM
jcheng
jcheng's Avatar
http://www.amazon.com/Ernst-Manufacturing-964-Yellow-Stand-Covers/dp/B005Z2XA8M http://www.amazon.com/Ernst-Manufacturing-964-Yellow-Stand-Covers/dp/B005Z2XA8M
Old 12-08-13, 08:38 AM
4TehNguyen
4TehNguyen's Avatar
should get a set of rhino ramps. I try to use ramps wherever I can, just a lot easier and safer than jacks.
Old 12-08-13, 08:53 AM
SonyHome
SonyHome's Avatar
How does this protect/used with the pinch weld?
Quick Reply: Best way to jack the car?
