How to properly paddle shift.
Old 08-06-13, 12:55 PM
Therealman
Therealman's Avatar
Default How to properly paddle shift.
I just bought a 3IS 350 Fsport and I'm not very experienced with paddle shifters. So if anyone on here knows or is an experienced person with this can help me out thanks I usually just shift when almost to redline I don't want to mess up my engine by doing it all wrong thanks for the help.
Old 08-06-13, 01:24 PM
palidino
palidino's Avatar
u can shift whenever you want/before red line.
Old 08-06-13, 03:16 PM
dojoman
dojoman's Avatar
If you're just driving on the freeway I don't recommend waiting to shift until red line. This will kill your gas mileage and long term engine life. I normally shift before I hit 3500 rpm. Another trick is listen to the engine instead of looking at the rpm.
Old 08-06-13, 03:27 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
A tip is listen to and take a look at what rpm your transmission shifts from 1 - 2 - 3 - etc when you drive in "D" then mimic those rpm shift points in manual mode.
Then when you do want to have the occasional fun, engage the heavier foot , take the revs higher, and shift.
Old 08-06-13, 03:32 PM
Justin2JZ
Justin2JZ's Avatar
The car wont let you mess the engine up just dont wait til it bangs off the limiter. Wait until the proper break in period is done to run the car hard.
Old 08-06-13, 03:35 PM
r0shiro
r0shiro's Avatar
Have you driven stick before? If you have, then drive it the same. If you haven't, then either learn stick and mimic or don't use it IMHO.
There really is no difference other than no clutch and some automation to make it dummy proof so you won't blow it (engine) or damage it long term.
good luck.
Old 08-06-13, 04:44 PM
EthanV
EthanV's Avatar
Red light is 6,6k rpm. Max rpm is 8k do you know when the limiter kick in!
Old 08-06-13, 04:54 PM
driven5373
driven5373's Avatar
Is there anyone who uses the paddles to shift most of the time?
I mostly paddle shift in my current car (with dual clutch) and switch to auto during heavy traffic or for hard launches from a stop.
I wish the IS350 F had stick shift. If it did, I probably would already own one.
Old 08-06-13, 05:01 PM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
I never use the paddles in the IS (it's just a gimmick with a conventional auto). But I do use the paddles on the 12C regularly, but mostly leave it in A.
Old 08-06-13, 07:48 PM
r0shiro
r0shiro's Avatar
maybe with the 6-speed, but the 8-speed seems legit. Either way, if you (not you) are not racing i see no real point using the manual mode in an automatic car. Other than to say...i use the paddles/shifter.
Old 08-06-13, 08:27 PM
driven5373
driven5373's Avatar
One point I could see if you want the sharper handling of Sport/Sport Plus modes, but do not want to keep the engine in low gearing and on the boil all the time.
Old 08-06-13, 08:35 PM
r0shiro
r0shiro's Avatar
the S+ mode works independently from M mode. the handling is there in Auto mode.
Old 08-06-13, 09:22 PM
AndyL
AndyL's Avatar
Does it mean when the car is S+ mode and you put your transmission in M mode, the AVS would not be activated to make the suspension stiffer?
Old 08-06-13, 09:38 PM
r0shiro
r0shiro's Avatar
The AVS is activated by the S+ mode NOT the manual shifting mode.
S mode - controls the engine and transmission
S+ mode - controls the steering and suspension
D driving mode - car shifts into gears for you
M driving mode - you shift into gears manually (with some caveats)
That is as clear as I can make it.
Old 08-07-13, 01:25 PM
driven5373
driven5373's Avatar
You go into Sport mode by turning the dial, and into manual mode with the shifter on the console. Two different controls. I don't see why you wouldn't able to be both in sport mode and paddle shifting - but I don't own the car yet so I may be off base.
Quick Reply: How to properly paddle shift.
