'06 IS250 awd rear differential gears
Ring and pinion gears are shot. Spider gears are still good. Are there any aftermarket makers of these gears or is it a dealership only purchase? 800 bicks sounds a bit steep for gears. Correct me if I'm wrong, I believe this is a 4:10 ratio (Y10 differential) ?
there are only aftermarket diff/gearing for the RWD models. Some people have used the diff off of the IS-F or is300. For AWD, I don't think you can change the gearing because you would have to change it in both the front and rear diff or else you will get mismatched speeds and VSC warnings for days.
Since the is250 AWD was far less popular than the RWD model, chances are there are no aftermarket gearing options even if it was using an alternate diff
Thanks for the input guys. The used option is what I'm going with right now. But, to confirm, I should be looking for the Y10 differential with 4:10 ratio, correct?
yeah I was gonna say 800 is a bit steep when you can find a complete diff used for FAR less. Plus with a used diff, you can open it up and inspect it before putting it on the car
06 07 08 09 10 11 12 Lexus IS250 Differential Carrier Rear 65K AWD 4 10 Y10 | eBay
Shot an offer on this one. Got it for $250.
Jeff, sorry I haven't responded till now. Thanks so much for input. I have to ask, why are all these I've seen saying 06 thru 12? You're the only person who has said anything about there being a difference. What is the difference? Curiosity has the best of me now.
Jeff, great info. Thanks so much.
Update...
donor diff is in and working like a champ! Now, any of you guys wanna help me figure out the next problem? Reverse is having some issues.
Update...
Jeff Lange
08-18-23 07:46 PM
CAN-Toronto Fs: Torsen LSD from FRS
FMJ IS
13
03-26-15 01:35 PM
Jmags
02-05-11 08:46 AM
