tpms light
Old 05-31-15, 10:46 AM
Rontrell
Rontrell's Avatar
Default tpms light
I recently switched wheels with another friend that has a IS350 & now my tpms light will not go off ... is it because his monitors aren't recognized by my car?
Old 05-31-15, 11:03 AM
pheonix72
pheonix72's Avatar
The sensors need to be registered to your car ECU. Most tire shops will be able to do this. Make sure you register it as 2nd set of sensors if you are keeping your original wheels.
Old 05-31-15, 12:52 PM
Rontrell
Rontrell's Avatar
How can I register the new ones?
Old 06-01-15, 01:06 PM
pheonix72
pheonix72's Avatar
You cant register the new ones unless you have the scanner to read the ID of the sensors and a special tool/softwarw to load them into the ECU.
Old 06-01-15, 04:45 PM
Rontrell
Rontrell's Avatar
Oh ok. .. The guy at Toyota dealership wad trying to say the sensors are bad & need to be replaced. ... he failed to mention that they had tools to do such
Old 06-01-15, 04:49 PM
Rontrell
Rontrell's Avatar
Default Scanner
We have a scanner at work I wonder if its capable of doing such?
Old 06-02-15, 07:12 AM
Bichon
Super Moderator
Bichon's Avatar
pheonix72 gave you the answer in the very second post. Take it to a good tire shop that has a TPMS tool like the Bartec, not to a car dealer than doesn't. The Toyota dealer probably just has a Techstream scanner. While you can do it with a Techstream, it would require dismounting all four tires, getting the serial numbers off of the sensors, and then mounting and balancing. A shop with a Bartec walks around the car with the tool, then plugs it into the OBD-II port and is done in less than five minutes.
Old 06-02-15, 03:58 PM
Rontrell
Rontrell's Avatar
Thanks fellas for the helpful info!
RayKnight
GS F (2016-present)
05-11-17 05:31 AM
RoseHill1
GX - 1st Gen (2004-2009)
12-28-13 03:35 PM
Looftie
Wheels, Tires & Brakes Forum
12-29-09 09:01 PM
moo_juice
CL of Hawaii
01-23-09 02:41 AM
Lilflip#2
06-09-08 01:15 PM
Quick Reply: tpms light
