IS350 Front-End Shivers - Idling at Stop Light
Old 05-12-15, 01:25 PM
cherishzm
cherishzm's Avatar
Default IS350 Front-End Shivers - Idling at Stop Light
My 07 IS350 runs great, but when it's idling at a stop light, the front-end of the vehicle shivers in D mode and my wife in the passenger seat can feel it, too. If I put it in 'N' or 'P' mode, shivering seems disappears. It idles at around 650-700 RPM.
I've done searches here but can't seem to find answers as to what may cause the shivering.. What would be possible causes of rough idle / shivering at idle?
Old 05-12-15, 01:39 PM
pheonix72
pheonix72's Avatar
Does the car RPM fluctuating or stay stable at idle? You might have worn-out transmission and/or engine mounts if the problem goes away by shifting to Neutral.
Old 05-12-15, 01:50 PM
cherishzm
cherishzm's Avatar
Thanks for the reply. RPM is pretty stable during idling.
Is it common for tranny or engine mounts going bad on 2nd Gen IS vehicles? I do know it's very common with Honda/Acura FWD vehicles..
Gville350
Gville350's Avatar
^I was going to mention engine/trans mounts as well.
As our vehicles get older, the likelihood of those needing replacement mounts will become more and more.
Old 05-12-15, 01:54 PM
cherishzm
cherishzm's Avatar
I forgot to mention that when I shift from N to D and vice versa, I can feel the car's movement even with a foot on the brake.
Old 05-12-15, 02:18 PM
cherishzm
cherishzm's Avatar
Is there a way to test if tranny or engine mounts are bad?
Old 05-12-15, 03:11 PM
pheonix72
pheonix72's Avatar
From what you described, i think your engine mounts are starting to wear out (as opposed to Tranny mount since the vibration isn't there when you are driving). It is a bit hard to test when they are slightly worn out but the classic symptom is increasing vibration at idle in "D". You could try to look for visible sign of wear/damage. I think our 2IS have 3 set of mounts?
Fortunately, the parts isn't expensive and somewhat easy DIY.
Old 05-13-15, 04:50 PM
Gville350
Gville350's Avatar
From my reading, our mounts are semi-fluid filled; so perhaps they've leaked out or just deteriorated to the point of needing replacing. Yes, they're relatively cheap and easy to replace with a garage, a floor jack, jack stands, a block of wood (to hold the engine up during mount removal/install), and basic hand tools.
trdsw20
03-30-21 08:48 AM
JDMV8
IS F (2008-2014)
100
02-04-21 03:30 PM
SamySalmon
02-27-17 12:29 AM
Elex
ES - 5th Gen (2007-2012)
08-07-09 05:03 AM
ryanSC300lover
Performance & Maintenance
02-15-07 03:00 PM
Quick Reply: IS350 Front-End Shivers - Idling at Stop Light
