How much bigger is the 350 chassis as opposed to the 250?
Old 04-24-15, 03:11 PM
laobo979
laobo979's Avatar
Originally Posted by RUCKER
Alright well I'm just going to go ahead and say the is350 is basically the is250 with a wide body kit on it so all sides are happy because I refuse to believe that boosheeit.
Then you should go into local dealer to argue your wide body theory to them. Come back and let us know what they say.
Old 04-25-15, 10:46 AM
darkdream
darkdream's Avatar
It doesn't even make economical sense for a car company to make two difference chassis for the same car. Most car companies use the same chassis among numerous models.
Old 04-27-15, 04:53 AM
SilvaIS350
SilvaIS350's Avatar
Here you go. Tells you all the info difference between the IS350 and Is250.
Old 04-27-15, 08:10 AM
jennie
jennie's Avatar
The IS350 is $89.99 wider than the 250, not including the gas it takes to go to Costco to get your eyes checked.
Old 04-27-15, 11:24 AM
smokyis350
smokyis350's Avatar
I've seen a lot of IS250 with 17s. I never seen a IS350 on 17's. Always on the 18's.
Old 04-27-15, 11:34 AM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
^^^^OK - and
Lou
Old 04-27-15, 11:44 AM
smokyis350
smokyis350's Avatar
Originally Posted by flowrider
^^^^OK - and
Lou
That may contribute to the fact that it make it looks wider. Smaller wheels may give the perception of a smaller chassis to some people.
Old 04-28-15, 02:33 PM
WylieKylie
WylieKylie's Avatar
This thread is A++, would read again!
First I was like: then then but now I'm definitely
Here you go, you'll have to take my word for it since you can't see the widebody of the 350, or the badge (which coincidentally I removed anyway) but here are two different sets of 17" wheels on my 350
Old 04-29-15, 07:09 AM
Tanoshii
Tanoshii's Avatar
※pours fuel on the fire※
But, your suspension is modified :3 maybe to fit those onto the widebody 350!
※Breaks out fire extinguisher ※
From Lexus...
IS250 Dimensions:
HEIGHT
1,430 mm (56.3 in)
WIDTH
1,810 mm (71.3 in)
WHEELBASE
2,800 mm (110.2 in)
OVERALL LENGTH
4,665 mm (183.7 in)
IS350 Dimensions:
HEIGHT
1,430 mm (56.3 in)
WIDTH
1,810 mm (71.3 in)
WHEELBASE
2,800 mm (110.2 in)
OVERALL LENGTH
4,665 mm (183.7 in)
CURB WEIGHT
IS 250 RWD............................................1,570 kg / 3,461 lb
IS 250 AWD.........................................1,655 kg / 3,649 lb
IS 350 RWD.........................................1,630 kg / 3,593 lb
IS 350 AWD...........................................1,695 kg / 3,737 lb
Well OP, aside from weight changes due to drivetrain and engine differences, you can easily see that... Well, if this theory was a fun Hasbro game, then I sunk your battleship o_o;
Old 04-29-15, 09:50 AM
valeoray
valeoray's Avatar
Lowered cars makes them look wider too. Also wider tires and/or tires that poke or are more flush with the fenders help make that wide look.
ddvette9
11-23-16 10:40 AM
Alant514
07-30-16 11:55 AM
Macgyver
10-31-08 11:33 PM
Lexusman44
04-29-07 06:05 AM
dennis250
11-24-05 11:24 PM
Quick Reply: How much bigger is the 350 chassis as opposed to the 250?
