Suspension still Messed
Old 04-10-15, 11:08 AM
sparta3993
sparta3993's Avatar
Default Suspension still Messed
2006 is250 sport with ML driver side rear is lower than the rest of the car. Just the driver side rear end sits lower than the rest of the car. Car only has 38000 on it, car has been sitting for 5 months (wintered) inside heated garage. Babied, has not been driven hard. Has never made any noise ever.
Update: car is on all new wheels. Took it to lexus and they said nothing about it. But it looks like its freaking lower and on a flat surface (level was used) it still seems to be sitting low.
I looked underneath the car and seems like the plastic under the damper is damaged. but thats about it.
What the hell can I do? besides expensive coil overs to fix it?
Is there anyway to Adjust this problem?
Old 04-10-15, 11:15 AM
laobo979
laobo979's Avatar
Is the rear making any noise over bumps as you drive it? Put your weight on the trunk and bounce the rear up and down for noise. Only reason I see could be an blown shock. But you gonna have to jack the rear end up take the wheel off and look around. You installed new tires make sure your front are your front tires and rear are your rear. Since they are different front to rear.
Old 04-10-15, 11:19 AM
sparta3993
sparta3993's Avatar
Not a single sound. Did a 4 hour trip yesterday too. Not a single noise from any range 0- 90 miles/hour. I was holding 80 for the most part, Taking british columbia corners hard and fast with no problems uphill and downhill. No noise breaking. Ride was comfortable no random bumps or noise. and handled like a dream no traction loss.
I don't know what to do?
Old 04-10-15, 11:22 AM
getafewliv
getafewliv's Avatar
Yay for British Columbia
I know that the car does lean more to one side with springs/shocks, whether it's to this extent, I am not sure.
If you want it perfect, you would have to put in a set of adjustable coilovers.
Old 04-10-15, 11:28 AM
sparta3993
sparta3993's Avatar
Hahah where about are you?
alright Im going to unmount the tire and look around and see what wrong.
Ill post pictures tonight of the springs.
Old 04-10-15, 01:02 PM
Gville350
Gville350's Avatar
Hire a short person to sit in that rear seat to weigh it down.
Old 04-10-15, 01:25 PM
VTsuckah
VTsuckah's Avatar
Sounds like a blown strut.
Old 04-10-15, 02:00 PM
getafewliv
getafewliv's Avatar
I'm in the Burnaby area.
Shock not strut.
Usually you would feel something fairly obvious if a shock is blown. Either a floating feeling over bumps, or a rougher ride.
The mileage is also quite low for stock shocks to go out. Mine went out at about 100,000kms but that was mostly because I threw in H&R springs. Before the springs my shocks still worked well.
Old 04-10-15, 08:38 PM
lysis250
lysis250's Avatar
Been there done that, the easiest solution is coilovers that's what I did and it solved the issue.
Old 04-10-15, 11:52 PM
smokyis350
smokyis350's Avatar
The driver side is always known to sit lower than the passenger
Old 04-11-15, 08:00 AM
sparta3993
sparta3993's Avatar
Why is that? And how much lower?
Old 04-11-15, 08:02 AM
sparta3993
sparta3993's Avatar
Shock not strut.
I'm confused bud looks like I got a strut not a shock, and it doesn't look like it is leaking.
Old 04-11-15, 08:30 PM
sparta3993
sparta3993's Avatar
Update with Better pictures and more information at the link below. Thanks guys
https://www.clublexus.com/forums/is-...-pictures.html
Old 04-12-15, 01:47 PM
LucianoLee
LucianoLee's Avatar
+1 my car's driver side is lower than the other side, both front and rear. Getting some BC coils soon...
Ciggy
01-17-21 08:03 AM
situman
04-25-16 06:17 AM
PEARL2
Suspension and Brakes
26
11-27-09 12:20 AM
fatts
09-21-07 09:47 AM
Quick Reply: Suspension still Messed
