TPMS - Check System Light - Help Needed
Hey guys,
I've been experiencing a problem with my TPMS in my 2IS. There's a light on the dash saying "Check System". Now, to give you some background info - I had a set of 20''s on the car for a couple of months. Then, when I put the stocks wheels on the light came on again. Notice that the light was on the whole time when the 20's where on the car, then it went off for the first couple of days when I put back the stocks. I've tried several methods, but nothing seemed to work. Today, I took the car to have a tech put a scanner and it gave him the following code: B2199. I tried googling it, but no solution was found. Does anyone know what this code is? Any solution to fix it? Can anyone help me, pls?
I am afraid that my car won't pass the emissions test because of this light on. Also, I plan to trade it for a 3IS in the near future, so I definitely don't want to trade it in with that light on and have the dealer give me less for my trade because of the light.
Any help is appreciated!
My guess would be to replace the sensors, since they are always on the stock ones. The sensors usually last about 100k miles depending on the driving cond.
Not so sure if I need to, but knowing how tough some inspectors can be I rather be safe! I thought the same, replacing them all. Just not sure if I want to spend that kind of money right now
So with the tpms sensors its still on? Either you need to have someone sync them or you need to select the right set of sensors from the car menu since the car can store two sets of sensors. Scroll through the < O > button on left of your steering wheel to change which sensors the car is reading
try to switch between MAIN and 2ND on the speedometer section.
But since it worked before, I dont think it is a syn problem.
