Replace ignition coils with spark plugs?
Old 10-14-14, 02:00 PM
halloo
halloo's Avatar
Default Replace ignition coils with spark plugs?
Hello,
I have an is250 and wanted to know if you guys would recommend replacing the ignition coils when replacing the spark plugs? If so, what is the part number for the ignition coils?
Thanks in advance!
Old 10-14-14, 02:09 PM
laobo979
laobo979's Avatar
No unless you have issue with the coil itself.
Old 10-14-14, 04:20 PM
Gville350
Gville350's Avatar
^Exactly...if it ain't broke, don't fix it!
Old 10-14-14, 05:40 PM
NYKnick101
NYKnick101's Avatar
the coils are 90 a piece after market and $147 a piece OEM. and your car needs 6 of them. If you got money like that, the go ahead but definitely not necessary. Just the plugs would do fine
Old 10-15-14, 08:33 AM
halloo
halloo's Avatar
Hellz no.. wish i had that kind of money. i didnt know they were 90 a peice.. i thought 90 for a pack of 6.
Guess I'll just replace the plugs then..
Thanks all!
Old 01-19-15, 09:38 AM
Itsablurr
Itsablurr's Avatar
Well, then you would wait until they start to fail, and leave you limping along the road with low power until you can get them replaced.... Been there, no thanks. Stay ahead of it.
Generally ignition coils in my experience should be replaced every 100k or so. Basically swapped out every other plug change.
Old 01-19-15, 05:47 PM
LucianoLee
LucianoLee's Avatar
My last is350 had 135k miles when it got rear ended. I changed the plugs twice at 60k and 120k. Never had any problem with the coils.
I would just do the plugs first. If the coils act up, you can always change them after that.
Old 02-03-22, 08:07 PM
MrHarris
MrHarris's Avatar
I have a 2008 IS250 6AT and just am changing them now at 194k miles. My up stream air fuel ratio sensors are also needed to be replaced as well as my camshaft intake and exhaust position sensors
firestart9 (02-04-22)
PlatES300
07-16-18 05:12 PM
mkstew
06-01-18 05:45 PM
2GSTony
12-12-14 11:46 AM
LexBrett
04-25-13 05:19 AM
dry-fly
09-29-11 06:10 PM
Quick Reply: Replace ignition coils with spark plugs?
