Help cleaning this wheel stain!
Auto Detailing Master
This is common with bare metal... they are very easily damaged with hard water. Even clear coated pieces can easily be damaged with hard water... it is nasty stuff.
You will need to refinish the wheels to some degree to remove it. If you're lucky and the spots are not that bad, you will be able to remove them with a general metal polish on a micrfiber towel or foam polishing pad by hand. If they are more severe, they will need to be removed by machine polishing, and if they are quite deep, they will need to be sanded first.
Since you've already tried polishing by hand, machine polishing with a heavy polish would be the first thing to try and then wetsandimg would be the next step if that didn't work as Zach said. Even if you want to replace the lips I'd get the current lips cleaned up so you can sell them and recoup some of your money.
Rich27
Wheels, Tires & Brakes Forum
12-25-08 06:18 PM
4HunDo
02-19-03 12:36 AM
