2012 LED\HID Headlights in 06 Help?!
i did the wire swap so the LED were 100% all the time too
My set from Sewell didn't work when I plugged it straight in for some reason.
I used a circuit tester to find the wire in the plug that it should have used to power it up and ran my own wire instead.
@SKStark when you say you rewired it, how did you do it? It sounds like you might have ran a wire to the lights, you can do what I did and run a wire from the ignition so it turns on when you turn the car on.
