Oild Filter Question
Old 07-19-14, 08:21 AM
KtIS
KtIS's Avatar
Default Oild Filter Question
I trying to Purchase a Oild Filter and engine oil and bring it to the auto store and let them do it , when i check online , someone sell 04152-YZZA3 , and someone sell 04152-YZZA5 , my vehicle Model is 2009 IS 350 RWD . which one i should buy it ? also , Mobil One sell two different 5W-30 too , Gold and Silver , what is the different , which one better to me .
Old 07-19-14, 08:33 AM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
04152-YZZA3 and 04152-YZZA5 are both the same oil filter, the A5 comes with an extra o-ring and drain fitting meant for the AWD models. YZZA3 is the correct RWD oil filter, but either will work just fine.
More information I posted before.
Jeff
Old 07-19-14, 02:09 PM
KtIS
KtIS's Avatar
Ok , i got it . Thanks man , how about the oil ?
Old 07-19-14, 05:00 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Information on the differences between the versions of Mobil 1 here: http://www.mobiloil.com/USA-English/...Oils/Oils.aspx
I don't see too much of a reason to run anything but the silver-cap, the engine isn't spec'ed for synthetic anyway, and if you aren't going to run extended intervals, I don't think the additional additives in the extended life oil are required.
Jeff
Old 07-19-14, 08:03 PM
KtIS
KtIS's Avatar
So , if i keep use the gold one will get the engine longer life , is it ?
Old 07-19-14, 08:19 PM
panda08
panda08's Avatar
As long as you change your oil regularly, you will be fine with either cap color
leehom
NX - 1st Gen (2015-2021)
10-01-22 09:17 AM
Lexmex
RX - 1st Gen (1999-2003)
13
12-13-16 06:42 PM
NikonGuy
12-20-14 03:15 PM
FSportJoe
03-09-14 08:26 PM
coolite
05-01-12 09:40 PM
Quick Reply: Oild Filter Question
