Headlight help
Old 07-18-14, 06:20 PM
AZ JB
AZ JB's Avatar
Default Headlight help
So I just replaced the headlight bulbs because the passenger side one was out. When I put the new bulb in and tried to turn on the lights it is still out! I tried disconnecting and reconnecting the harness numerous times but it still won't turn on. Anyone have any other ideas for troubleshooting why a headlight won't turn on. The DRLs and high beams work. But for whatever reason I can't get the main HID bulb to illuminate. Really wanting to try to figure this out without spending an arm and a leg getting it diagnosed at the dealership.
Old 07-18-14, 09:03 PM
idoke1
idoke1's Avatar
It could be a wiring issue. Look and follow the line to see if there are any shortages. It may also be a faulty ballast.
Old 07-18-14, 11:25 PM
AZ JB
AZ JB's Avatar
Wasn't able to find a wiring issue from what I could see.. Do you know how to test the ballast?
Old 07-19-14, 12:10 AM
Snyperifle
Snyperifle's Avatar
Well.. you could have a bad ballast
Old 07-19-14, 12:14 AM
AZ JB
AZ JB's Avatar
I'm thinking the same thing.. Is there a way to test the ballast without going through the hassle of removing it? I'd prefer to be sure..
Old 07-19-14, 06:36 AM
AKhanis350
AKhanis350's Avatar
Take the bulb from the side that is working and plug it to the one that isn't working to trouble shoot. This will help identify if the ballast is bad (since you know the bulb works).
You can find replacement ballasts on eBay or look in classifieds. I also bought a set of HID bulbs from eBay and they have been working well.
Let me know what happens...
Old 07-19-14, 11:10 AM
AZ JB
AZ JB's Avatar
Well I bought two brand new bulbs and replaced both so I am guessing it must be the ballast. That really sucks..
I looked up buying a replacement and found them for ~$120. That part doesn't bother me… the part that I am confused on is how to replace it. I was researching trying to find DIY guides and so far everything I am reading is saying you have to remove the entire front bumper, then remove the entire headlight and then disassemble that as well. Does this sound right? I may have to take it somewhere because I don't have the time to do all of that right now.
Old 07-19-14, 11:27 AM
knguyenk
knguyenk's Avatar
That's exactly the procedure to replace the ballast. Otherwise the quicker but more expensive way is to get the headlight with the ballast together to save time on the disassembly of the headlight.
Old 07-19-14, 11:29 AM
AZ JB
AZ JB's Avatar
Awesome, lol.
Well I guess I'll be calling around for quotes! Thanks for the help guys.
ksiq
ES - 5th Gen (2007-2012)
40
02-01-21 06:43 AM
tbarrios
09-29-18 04:42 PM
empower
06-13-14 10:44 AM
tdoom15
11-15-12 02:53 PM
Sash
02-02-09 09:22 PM
Quick Reply: Headlight help
