Fsport question
Fsport question
Just wondering if anybody else has run into this. I have a 2010 IS 350 C Fsport and I need to replace the brakes the dealer is quoting me $5200 does anybody know if there's a way I can put regular IS 350 brakes on the car?
Yes this is what they are saying , I have 80,000 miles now. They are saying I need replacing . The service guy said I could only use Fsport brakes. I am very skeptical.....
I think they are saying that you need to replace the rotors as well as the brake pads. The rotors are the ones that are driving the price up because for each rotor, they cost about $700 something each at dealer price which is freaking ridiculous. Being that the drilled rotors cannot be resurfaced, they want to replace the rotors and the brake pads at the same time.
To answer your question, Yes you can switch your brakes to regular IS350 brake calipers, pads, rotors, etc.
Forget about their ridiculous $5200 quote and you don't need F Sport brake kit unless you have money to burn. I think what you need is to replace the rotors and pads. There are 2 options:
1. Buy the OEM rotors and pads from Sewell which is also official Lexus dealer. The ones below fit perfectly on your ISC.
Rotors is here http://is.sewellparts.com/accessorie...2010/6244.html
Pads is here http://is.sewellparts.com/accessorie...2010/1894.html
2. You can go with aftermarket rotors (Stop Tech, Powr Stop...) and pads (Hawk, PosiQuiet...) and make sure it fits your car.
I advise going with option 1, OEM has really good brake performance.
So are the IS350 F Sport braked different that the normal IS350 brakes? I am assuming they didn't install the F Sport BBK from the factory. Even if they have to replace the entire IS350 calipers, rotors and pads I can't see how it can add up to $5200 which is more than the F Sport BBK upgrade. Stealership at its worst here.
Here are the part #s
FRONT LF DISC W/O HAT 31.37.1201.99
FRONT RT DISC W/O HAT 31.737.1202.99
PADS 309.12470 PERFORMANCE PADS
PADS 105-12470 POSI QUIET CERAMIC
REAR LF DISC W/O HAT 31.626.1201.99
REAR RT DISC W/O HAT 31.626.1202.99
PADS 309.06090 PERFORMANCE PADS
PADS 105.06090 POSI QUIET CERAMIC
HOPE THAT HELPS YOU GUYS OUT
kingofbyte (05-19-21)
