he broke that 7/8 pin clip for the USB. IDK why you need that for it to function if you dont use the USB option.
Check and see if the unit as an open/push contact switch. Some newer computers have a contact switch on the casing that pushes a button that needs to be depressed/closed to start the PC. Its a saftey switch to avoid static charges to computer electrical components. See if the unit has that, it may not start while its open
Under steering wheel to the left, just pull the small door (or something similar).
The other fuses require you to raise your hood, you can find it directly in front of the drivers side inside a small box with a lid. My memory is a lil foggy but I hope this helps.
Idk if thats gonna help because when I put my old one in, it works perfectly
