Helpppp!! problem in my car..
Old 04-08-14, 11:40 AM
yow123
yow123's Avatar
Exclamation Helpppp!! problem in my car..
i have a second generation and it has a problem that's really bothering me.
when i get up in the morning and switch the car on to go to work,, it starts shifts and drives normally,, but after half an hour or so when i get into traffic ,, when the gear changes from 1st to 2nd the car bounces and becomes heavy on acceleration ,, but when i kick down the gas pedal this doesn't happen at all.
the second problem is when i want to park ..
here is the situation,,
when i want to park and i put the CAR IN R (REVERSE) and reverse then i put it back into D (DRIVE) the car jerks and shuts off!
this is what comes up in the dash
i have had it diagnosed and there are no codes!
please help me figure out the problem because its really annoying
Old 04-08-14, 11:42 AM
600rr05
600rr05's Avatar
something for sure isn't right about that. Who diagnosed the car ?
Old 04-08-14, 11:44 AM
yow123
yow123's Avatar
3 shops diagnosed the car .. and every time there are no codes!!
Old 04-08-14, 11:57 AM
600rr05
600rr05's Avatar
Have you been able to reproduce the problem with a tech ?
Old 04-08-14, 11:59 AM
yow123
yow123's Avatar
i went to a tech .. and he told me that i need to change the ecu !! but the problem is that he's not 100% sure
Old 04-08-14, 12:07 PM
vicsis250
vicsis250's Avatar
My recommendation is take it into a real tech that know our cars. Your local Lexus dealership will charge you a diagnostic fee but a least you will know what's wrong with it. The reason you're not getting a code because it's not an electrical problem it's mechanical mechanicals don't always put up codes. To me and I'm no expert from what you have explained it sounds like it might be problems with you transmission or a solenoid. Good luck and let us know what Lexus says.
Old 04-08-14, 12:19 PM
FSportIS
FSportIS's Avatar
may be carbon built up related??
Old 04-08-14, 12:25 PM
yow123
yow123's Avatar
how can i be sure if its carbon build up ??
Old 04-08-14, 12:49 PM
600rr05
600rr05's Avatar
I thought about this but when it happened to me it threw a code
Old 04-08-14, 12:58 PM
FSportIS
FSportIS's Avatar
For your problem, I think you should see Lexus dealership, at least let them diagnose the problem. They are best with our cars.
Old 04-09-14, 12:39 AM
Boy1109
Boy1109's Avatar
Totally agree.
Old 04-09-14, 01:31 PM
Sffd103
Fire Slayer
Sffd103's Avatar
try disconnecting the battery for 15 min.
Old 04-09-14, 01:57 PM
06350F
06350F's Avatar
Random question but what grade of gas are you running?
Old 04-09-14, 03:06 PM
DryEye
DryEye's Avatar
Sounds like a MAF sensor problem, you either need to clean it or replace it.
Also, as stated in a previous post, have you tried disconnecting the the battery for 15 minutes to see if that helped?
Old 04-10-14, 12:17 AM
XhyDra
XhyDra's Avatar
This is not a carbon issue. Sounds like the transmission could be having issues. Unplug the battery for 15-30 min. Let the system reset. Turn on ECT PWR to see if anything changes. Do you have an AWD IS? You should have this checked by a competent Lexus mechanic.
Quick Reply: Helpppp!! problem in my car..
